66 327 brackets and pulleys
Can somebody help to find the correct brackets & pulleys for my 66 c10 with power steering and air. I have some but I don't know if they are correct. Pictures and sources would be great. Thanks
![]() Join Date: Aug 2008
Re: 66 327 brackets and pulleys
The top is a cast pulley for the air on the water pump , there is also a cast and steel together for the bottom on the 327 that carries the ps belt
![]() ![]() Join Date: Apr 2012
This first thread is not the best. The second one shows more with AC and PS.
http://67-72chevytrucks.com/vboard/s...d.php?t=603125 http://67-72chevytrucks.com/vboard/s...d.php?t=633432
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
I have a couple extra AC pulleys ,Lmk what you need.
water pump pulley, crank pulleys and all the a/c brackets
