Throwout bearing size.
Trying to get the last of my parts together to install motor and trans in the frame. 62 c/10 ,350 SB, factory bell housing with hydraulic clutch, Saginaw car 4 speed trans. Which length throwout bearing do I need, or is that dependant on the clutch set itself? It is also a 1 piece rear main seal block if that matters.
#2 | |
Enjoy your truck
Re: Throwout bearing size.
Short answer to your question - use the stock set up. Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
#3 | |
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
I thought it was most likely dependant on the pressure plate, but then again its been yrs since I messed with a manual. Looked up 62 c/10 with 283 and found a zoom kit with 11 in ,10 spline clutch disc. Hopefully in a few weeks, it will go together.
