Old 02-23-2016, 06:48 PM   #1
vweater2001
vweater2001's Avatar
1969 GMC Stepside SWB Tailgate Trunnion
Okay so I just got the poly trunnions from LMC for my truck per http://www.lmctruck.com/icatalog/cb/full.aspx?Page=33 item#4.
With that said, how do they go on? Does the bolt go on towards the bed/metal side of the side step panels or towards the inside of the tailgate? What am I missing here? Item came with poly trunnions 1 bolt & 1 lock washer. I just want to make sure I install them correctly and finally get my bed on correctly.
Thanks in advance guys!!
Mando
"If you aint first your last!!"
1969 GMC C1500 Stepside Shortbed - daily driver
Mando
vweater2001 is offline   Reply With Quote
Old 02-23-2016, 09:45 PM   #2
RonG
Re: 1969 GMC Stepside SWB Tailgate Trunnion
On my '69 short step the head of the trunion bolt is outboard threading into the trunion.
RonG is offline   Reply With Quote
Old 02-23-2016, 10:50 PM   #3
swamp rat
swamp rat's Avatar
Without seeing a picture of the bed and tailgate, i guessing you slip the trunion into the tail gate, hold in place then run the bolt thru the bed into th trunion, not sure how ya hold the trunion to tighten
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-25-2016, 02:10 PM   #4
vweater2001
do you know the size of the bolt I need as I don't have a bolt for either side? my bed doesn't have those trunnion cups where the trunnions would sit in like other trucks...is that normal and are they needed? I just want to make sure I bolt it up correctly and not lose my tailgate while driving.
Mando
Old 02-25-2016, 02:15 PM   #5
vweater2001
Ron,
so what holds the bolt once it goes through the trunnion? Is there supposed to be a nut on the other side of the bed or should the bolt be threading through the bed? I'm new to these trucks and have never had to fix these but want to make sure it's done right?
Mando
Old 02-25-2016, 02:39 PM   #6
In The Ten Ring
I tried the poly trunnion from LMC back in 2003. WASTE OF MY MONEY. It wasn't the right size and I tossed it aside and went back to my original steel ones. They make lithium grease for a reason (mine squeaked badly was all).
In The Ten Ring is offline   Reply With Quote
Old 03-17-2016, 07:00 PM   #7
1966chevy
1966chevy's Avatar
1954-1987 Chevy GMC Truck Stepside Tailgate Hinge Trunnion "Patent pending"
Ultimate Hinge Trunnion (4 Piece Set) made of Stainless Steel/Delrin replacement part!
Made in USA!
These are very quiet while opening and closing the tailgate. See the pictures
My product was mentioned on the Hotrod network magazine, on-line. Silent 'Gate.
hotrod.com
new-classic-truck-products
Also mentioned in Classic Truck magazine Feb 2016 issue, released on the stands Nov 20th 2015. Check them out! Thanks
Available on my Website: tdtrunniondesign.com
Also Available on Ebay right NOW!
http://www.ebay.com/itm/171718930810...84.m1555.l2649
These are hinge trunnion replacement parts to upgrade your Chevy Stepside Truck.
The Trunnions are manufactured from Delrin and 303 stainless steel.
I have a picture listed of the replacement trunnions that are zinc plated which will still rust on your truck. I also show the original trunnion that was removed and has rusted and made that awful sound while opening and closing the tailgate. You can reuse your bolts and lock washers, but would recommend you use stainless steel bolt and lock washer. Be sure to use an antilock lube when reinstalling your Trunnions, prevent bolt lock! Just remove the bolt with lock washer, replace with these stainless steel hinge trunnions and bolt back on your truck just in reverse of how you removed it from the truck.
No more greasing the trunnion, No more rusting, No more noise with a huge improvement, smooth opening and closing of your tailgate! You'll love it!
Free shipping USPS in 50 states.
Ebay Product reviews
Fast shipping and worked perfect.
67 68 69 70 71 72 Chevy/GMC Truck Fleetside tailgate SS Trunnions Hinge SET
thanks for the trunnion hinges, fast shipping, great price, will buy from again!
58 59 60 61 62 63 64 65 66 Chevy/GMC Truck Fleetside tailgate Trunnion Hinge SET
great part, really helped with the rattling tailgate problem
I have been hyping you up in instagram & the 47-72 truck forum. Great product!
Quick and easy...product is awesome, Thanks
Item as described, fast shipping...Thanks!
Great seller! Super fast shipping! Amazing quality product! Thank you!
Quality Product MADE IN THE USA well packed FAST SHIPPING thanks again
Quick and easy service with high quality parts.
1954-1987 Chevrolet GMC Truck Stepside Tailgate Trunnion Hinge SET
1966chevy is offline   Reply With Quote
Old 03-18-2016, 03:20 PM   #8
RonG
Originally Posted by vweater2001 View Post
Ron,
On my truck there is a slot in the trunion and a hole in the bottom of the tailgate. Line the slot up with the hole insert a screw driver to keep trunion from turning and screw the bolt into the internal threads of the trunion. Rong
