Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-24-2016, 08:17 AM   #1
aknovaman
Cool 8 foot LED shop light install videos
https://youtu.be/0-Jm0DLJwhM
Not the greatest video as I was in a hurry but these are definitely a great value. I got them off eBay for $30 each. Initial testing shows one strip puts out a close to the same lumens (light intensity) as the original two T12 fixtures.
Here is another video of 5 strips installed. They run directly off 120 volts and draw almost now current. I chose these because they use a common3 pin power cord off a hp style laptop. They come with a 12 inch power pigtail but I temporarily wired them using old lamp cords till the new molded power cords arrive.
https://youtu.be/5c5PPFlq9Hg
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 02-24-2016, 09:08 AM   #2
undertaker72
undertaker72's Avatar
Re: 8 foot LED shop light install videos
do you have the # to these , looking on evil bay they say88-119 each
I aint nobody DORK
1972 Cheyenne super k10 swb 350 4speed posi hooks
1934 ford 3 window blown 355
1969 Camaro hugger orange hounds tooth
undertaker72 is offline   Reply With Quote
Old 02-24-2016, 09:24 AM   #3
aknovaman
Buy a set of 10 and they are $30.
http://m.ebay.com/itm/Integrated-8Ft...d=410729038602
FMCDH GBU and GBA
Old 02-24-2016, 01:16 PM   #4
MalibuSSwagon
I got four 4ft long ones for around $11 each on ebay, pretty bright. Mostly bought them to see the quality, thinking of becoming a distributor since they work pretty good.
MalibuSSwagon is offline   Reply With Quote
Old 02-26-2016, 12:04 AM   #5
aknovaman
Lastly, for the cheapskates out there you can build these for about $15 each. Just not as pretty. I zip tied and taped the strips to a 8 foot 1x1 board and ran it off a 12 volt power supply. The strip drew 2.2 amps.
https://www.youtube.com/watch?v=wtdPQpS5Z_s
FMCDH GBU and GBA
Old 02-26-2016, 12:00 PM   #6
ERASER5
ERASER5's Avatar
Using your linc, 10 lights are $332.49. That's $300 ,ore than $30.00. Did someone oopps a decimal place?
The linc is confusing. Are these replacement lights or stand alone lights? The add says "use power cord" and later it say to "remove or bypass the original ballast and starter"
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 02-26-2016, 12:17 PM   #7
aknovaman
They sell several versions. The link is for 10 standalone bulbs that use a 3 prong laptop style or 2 pin electric shaver style power cord if you dont want to run a ground. They are standalone in that they dont need a fixture, tombstones or any kind of end brackets. They include a plug in 12 inch power pigtail.
The other versions are if you want to use existing fixtures, removing the ballast and connecting power through the bulb end terminals. I wanted to use the simpler version and remove my metal fixtures entirely. They also come with small metal brackets to screw directly to the ceiling and the tube aluminum back snaps into it fir a flush mount on ceiling.
These weigh less than 1 pound each nut are very rigid and wont flex much.
FMCDH GBU and GBA
Old 03-06-2016, 05:12 PM   #8
aknovaman
Final video install vid with 9 of the 8 foot tubes 12 inches below ceiling hanging on chains. going to mount to ceiling this summer/.
https://www.youtube.com/watch?v=nZnICAKiFfA
For the cheapskates out there here is an affordable option for less than $15 each 8 foot string.
FMCDH GBU and GBA
