Old 02-24-2016, 12:09 PM   #1
Kook87
Kook87's Avatar
6.0 ls swap in a 69 c10 exhaust suggestions
I am looking for suggestions on exhaust for my new 6.0 swap in my 69 c10. It has the Hedman mid length headers. I was thinking about 3" system. What have you used on your trucks? Mufflers, pipe size, x pipe or any other combo. Also what should I expect to pay? Mild steel and stainless. Thanks in advance.
Don't sweat the petty things and don't pet the sweaty things.
Kook87 is offline   Reply With Quote
Old 02-24-2016, 03:19 PM   #2
67 chevelle
67 chevelle's Avatar
Re: 6.0 ls swap in a 69 c10 exhaust suggestions
I did 2 1/2s with a crossover pipe , paid less than 300
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-24-2016, 05:27 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I used 2 1/2" standard duals out the back on the '67 Chevy Panel Truck. $250 with Flowmaster 40 knockoffs....
LockDoc
Leon
Old 02-24-2016, 07:59 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 6.0 ls swap in a 69 c10 exhaust suggestions
6.0 LS with 4l80e installed. 2.5" aluminum with 1.75" long tube ss headers and ss Megaflows.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-24-2016, 10:09 PM   #5
truckdude239
truckdude239's Avatar
625 buxs i paided for 2.5 inch with knock off flow masters i wish i could have find a deal liem other guys
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-24-2016, 10:27 PM   #6
LockDoc
LockDoc's Avatar
I have taken 3 trucks to the muffler shop I go to within the last 3 or 4 years. The '71 4x4 pickup, the '69 Suburban, and the '67 Panel Truck. Duals on all 3 with aluminized 2 1/2" pipe & 40 knockoffs. All 3 were $250 bucks each out the door. I would say you were taken advantage of on yours....
LockDoc
Leon
Old 02-24-2016, 10:32 PM   #7
Andy4639
Old member
Andy4639's Avatar
Mine was a little more @ $275.00 for everything from header flange back.
Old 02-24-2016, 10:44 PM   #8
'68 Newtricks
'68 Newtricks's Avatar
2.5" with crossover and SS 50 series flows with the '68/5.3
sounds good while leaving a stop light or getting on it, but quiet while cruising
I have 50 series on my two other trucks as well. Not the prettiest mufflers but I like the sound
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 02-25-2016, 09:00 AM   #9
Kook87
Kook87's Avatar
Thanks guys. Mine will probably be more complicated due to all the suspension mods.
Old 02-25-2016, 01:20 PM   #10
72longhornTX
I used the Hooker manifolds and their down pipes. Those were like $370 for the manifolds and $100 for the down pipes. Then I had 2.5 ran out back just like Andy's with Flowmaster 40s. Paid $415 for the exhaust work.
Current:
2012 Ford F-250 4x4 6.7 Powerstroke
1971 C-20 2wd 350/TH400
Former:
1979 C-20 2wd 350/TH400, 300+hp. Rattle can paint job
1982 K-30 454/700R4. 4in lift with 37" Goodyear MT/R's Lots of goodies - Trail clean up truck
72longhornTX is offline   Reply With Quote
Old 02-25-2016, 04:50 PM   #11
The Chainsaw
The Chainsaw's Avatar
A good mandrel-bent system with an X-pipe and some 18" case Pypes Race pro mufflers sound awesome. Tailpipes will tame the sound inside the cab, but will be a touch louder outside.
Something like that will be 5-6 hours labor @ around $50-80 per hour. This will be the best as far as fitment and power, but not the cheapest. I will always spring the money for something like this over the typical muffler shop job.
Even an only half decent, pinch-bent exhaust by the muffler shop down the street is within $100 of the option above.
The Chainsaw is offline   Reply With Quote
Old 02-29-2016, 01:53 AM   #12
Andy4639
Old member
Andy4639's Avatar
A couple of video's of mine.
