Old 02-24-2016, 02:38 PM   #1
hesaw00
shorty plug for vortec heads?
1st of all, in my 1st post I would like to say that this is an awesome collection of knowledge. I just bought my 1st C10 a few weeks ago and this is the 1st old/v8 ride i've had in a long time. Thanks for all of the great knowledge.
I have been searching high and low for shorty spark plugs for my crate motor. It's the standard 350/330hp i see commonly advertised. Just searching for regular plugs for vortec heads is a challenge...lots of talk about .715 depth vs .708, etc. and even with seasoned moderators there seems to be no consensus.
With that said...
Does anyone make a shorty plug for vortec heads? I just put headers on the truck and regular plugs are super tight.
hesaw00 is offline   Reply With Quote
Old 02-24-2016, 03:15 PM   #2
67 chevelle
67 chevelle's Avatar
Re: shorty plug for vortec heads?
Welcome to the board , I found this
"9:1 compression - AC - 45 heat range - I think the plug is a R45TS
9:75-10:1 - AC - 44 heat range - R44TS
I had the same engine in a camaro , and vortec heads on a chevelle , great running engines , they like 32 degrees total timing which is low , but what is suggested the 350 330 makes 350 horse with headers and a good carb ,, Remember they need a heater bypass to cool , are different in that way from other small block heads
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-24-2016, 03:32 PM   #3
Bigdav160
Bigdav160's Avatar
I think the vortec plugs require a longer reach. I've seen this one recommended
MR43LTS MR43LTS
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-24-2016, 05:28 PM   #4
hesaw00
Thanks. Truck has R44LTS plugs in it. And I ended up putting some R44LTS6 plugs back in it. I believe the "6" plug is the save as the R44LTS, just a wider gap of .60
But i'm looking for a shorter plug on the ceramic end...that will allow a little more clearance from the header tube. If your original suggestion is, in fact, a short plug...then I will check it out.
More VORTEC confusion - seems there's also no consensus on gap settings for these heads either... i've read .045 up to .065
Old 02-24-2016, 05:29 PM   #5
hesaw00
MR43LTS
Yes - definitely a longer reach, but I'm also looking for a shorter reach on the ceramic end of the plug
shorty; headers
