Ok, reinstalled the old motor oil pan dipstick and went to check the oil yesterday only to find the tip of the dip stick that goes into the pan is missing. What do I do, can this cause engine damage if left floating around in there?
As always thanks for your time/advice. info: 84 c10 305v8/th350
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
![]() Join Date: Nov 2003
Re: EMERGENCY! Broken oil dipstick!
Was the tip metal? If so, it's not floating so much as sliding around on the bottom of the pan, so I think you are OK.
If it was plastic, I still don't think you have a huge issue. It could get stuck on the oil pickup screen, but still probably not a huge issue. If it's a new motor, and it makes you feel better, pull it and find the tip. It would be an afternoon project, but that's not the worst thing to have to do.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
It was metal! Thanks that scared the hell out of me!
slap a big magnet on pan to keep in place and then lower pan later to find it
79 Chevy 2wd BIG10 350 TH400 |
your missing the lower half of the dipstick tube causing the dipstick to hit the crank and break. Very common issue and until you replace the lower part this will keep happening.
| Bookmarks |
