![]() Join Date: Sep 2015
What is this plug and where does it go?
![]() Join Date: Nov 2003
Re: What is this plug and where does it go?
That is your neutral safety switch. It mounts to the column about where you found it. You should find the square hole and the two screw holes in that area.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Old member
That looks like the neutral safety switch. It mounts to the steering column.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Awesome. Thanks guys will get under there and mount it. Not sure how I did not see it.
70+ ( Old Skool Club )
Is that also the back-up light switch? If so can your Neutral Safety Switch function properly and your back up lights not work?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
#6 | |
Old member
Thanks for the info Andy.
![]() ![]() Join Date: Feb 2009
That's REAL interesting. I haven't had back-up lights since I was a a young buck. Figured to get it right with the rebuild. Will be taking a good look at that switch, and the screw adjustment I can't visualize at this point.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Old member
Once you install it on the column it will have some slop in it. Take and get the neutral first and then see if the lights work when in reverse.
![]() The silver tips with the screw holes are slotted for adjusting it.
Should be just 2 screw holes, I believe that is not the original steering wheel but don't know the year of your truck.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Old member
Has it been changed over to a straight drive?
#13 |
![]() Join Date: Dec 1999
What year did they start using NSS?
Thanks Ron
Member #111 68 C-10 Daily Driver70 4x4 Project76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#14 |
Old member
That is a late 70's 80's model steering wheel. The opening should be on top of shaft towards the floor.
http://www.67-72chevytrucks.com/vboa...d.php?t=279795
#15 |
Hey Andy, this is a 1972 Blazer. Has been messed with but the SPID says it was a Auto. In that picture what year is the steering column on the left? It does not have a hole at the bottom of the shaft for the switch. Looks like it is higher closer to the steering wheel. As mine has no screw holes or anything close to the firewall.
Should there be a part number stamped in on this column? |
#16 |
I looked at that link. Looks like this might be a column out of a van. Some what they said the van columns did not have a spot for the NSS. Looks like I need to buy this switch that mounts to the trans.
Thanks for that link it saved a lot of searching! http://www.jegs.com/i/Lokar/625/BL-1...2/-1#reviewTab |
| Bookmarks |
