02-25-2016, 11:51 AM | #1 |
.023 vs. .025 welding wire
I have a little 110 wire feed welder with gas and lately I,m not having much luck finding 023 wire now,the smallest is 025.I,m almost running out..Do you think I will notice much,I,m doing patch repair on a quarter panel.
02-25-2016, 02:05 PM | #2 |
Re: .023 vs. .025 welding wire
Worst case you will have slightly more grinding to do since you are laying down slightly more material. I used .030" on my last body work project because I couldn't find .025.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
02-25-2016, 09:47 PM | #3 |
Post Whore
I've been buying all my wire off ebay...I just looked and there's plenty of .023 on there to chose from.
02-25-2016, 10:36 PM | #4 |
.023, .024 & .025 wire, contact tips and drive wheels are all interchangeable with each other. Different manufacturers use different discription but essentially all the same.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
02-26-2016, 06:55 PM | #5 |
I bought a 10 pound spool of .023 on Amazon just a couple of weeks ago.
02-26-2016, 10:51 PM | #6 |
I think a thousandth or 2 isn't a big deal. Have you looked into what a thousandth is?
