Old 02-25-2016, 01:35 PM   #1
mancad
Too much diff backlash?
I have a 1968 C20 with low miles (57k) and a No Spin axle. It seems like it has a little too much backlash in the differential. The drive shaft will turn a little over 30 degrees one way when turned by hand. Does that sound excessive? I cannot find a spec in the service manual.
mancad is offline   Reply With Quote
Old 02-25-2016, 02:48 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Too much diff backlash?
I don't think you can accurately determine backlash using that method.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-25-2016, 03:11 PM   #3
kwmech
What he said^^^. What you are feeling is the slop (for lack of a better term) in the complete set-up, especially with the posi. Totally normal unless you have an unusual noise or something else going on
Old 02-25-2016, 11:45 PM   #4
Mike C
Mike C's Avatar
The "No Spin" and mechanical lockers of that style including the later Detroit Locker and the LockRights are known for driveline backlash. But it's NOT the same as backlash in the gear set.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-26-2016, 12:39 AM   #5
mancad
Thanks for your responses. That was a generic use of the term backlash to cover any and all looseness in the differential. Didn't mean to imply the gear backlash used to set up the ring and pinion fit. Maybe hysteresis would have been more appropriate.
