Old 02-25-2016, 05:46 PM   #1
Nodnarb76
Nodnarb76's Avatar
Shift liknage/shiftter question.
I'm installing my LQ4/4L80E transmission into my 87 Suburban.
after I got the shift linkage connected, I had the idea to make sure I could shift through the gears afterward. I put the key in and turned the key to unlock the steering, and I can only shift from park into reverse. Do I need to have power hooked up to my harness/transmission to shift into the other gears, or did I do something wrong?
Seems like I could move the shifter tab through all the gears before I hooked it up but I could be wrong.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 02-25-2016, 08:38 PM   #2
boostedc10
boostedc10's Avatar
Re: Shift liknage/shiftter question.
I would look ok into the linkage. Something is more than likely not adjusted right. You do not need power to move the shift lever through the gears.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 02-25-2016, 09:14 PM   #3
Nodnarb76
Nodnarb76's Avatar
Thank you. That is what I thought. Just wanted to confirm.
I'll check the adjustment next chance I get.
Also just want to confirm, if I turn the shift rod on the transmission all the way clockwise until it stops means I'm in park right?
I'm using the stock shifter assembly, but I do have a Lokar unit if I can't use the stock one for some reason.
Old 02-25-2016, 09:16 PM   #4
boostedc10
boostedc10's Avatar
On the trans the shift lever should be all the forward for park. Toward the bell housing.
Brandon
Instagram: DRVFSTR
Old 02-25-2016, 10:12 PM   #5
Nodnarb76
Nodnarb76's Avatar
Thank you again!
Old 02-25-2016, 10:26 PM   #6
72MARIO
72MARIO's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=574800
I think there is another thread about shift linkage and 4l80 s. It will take some tweaking to make work
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
