Old 02-26-2016, 12:37 PM   #1
Sim6
Sim6's Avatar
Fuel pump question
So I'm running the stock s10 gas tank and a carbureted sbc. My s10 had the carbed 2.8 in it. Budget mined should I try the unit in the tank? Or use the pump on the block? If I use the one on the block do I have to install a valve in the bottom of the tank or will it pull from the existing lines? Thanks
Jeff
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 02-26-2016, 01:25 PM   #2
1project2many
Re: Fuel pump question
If there's a pump in the tank it can cause problems for a pump on the block. Use one or the other but not both.
If you don't like wiring you should use the one on the block.
1project2many is offline   Reply With Quote
Old 02-26-2016, 06:05 PM   #3
pugs
pugs's Avatar
carb'd 2.8 s10 had and electric fuel pump mounted under the drivers side on the frame
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 02-27-2016, 09:08 AM   #4
Sim6
Sim6's Avatar
Crap, I'm a dummy. Thanks.
Old 02-27-2016, 11:38 AM   #5
dsraven
just follow the fuel line back and see if there is also a filter inline somewhere and also see there is no kinks or flat spots on the line.
Old 02-27-2016, 10:11 PM   #6
Sim6
Sim6's Avatar
Lines are good, no filter. The more I think about it the filter was up front and the pump was on the block similar to the sbc.
Old 02-28-2016, 12:20 AM   #7
pugs
pugs's Avatar
well then your good to go
Old 02-28-2016, 12:41 AM   #8
1project2many
That's what I remember but it's been years since I've worked on one. The 4X4's all had 4.1 gears, though.
Old 02-28-2016, 02:21 AM   #9
mr48chev
mr48chev's Avatar
I'm not sure what size fuel lines an S-10 with a 2.8 had but the lines may be smaller than the engine wants.
I'd still do as DsRaven suggested and follow the line all the way back looking for kinks and smashed spots. Also I'd pull the sender out and take a look at the sock on the pickup tube. They can plug up over time and especially if the donor sat for a length of time or sat for some time with the gas cap off.
My ongoing truck projects:
Old 02-28-2016, 08:21 AM   #10
1project2many
As I remember, even the 2.5 powered S10's used 3/8" line. The tank had the same type of sock they used in other carbureted cars of the '80s and the filter was in the carb.
Good advice to check the fuel sock (filter in tank).
