68 C 10
![]() Join Date: Aug 2010
Air Managment
My truck is a SWB PB front A arms PB mild C-notch in the rear. Trying to decide on what type of air management system to run..
1. We could just do a standard valve type system $ 2. Run the AccuAir Switch speed system. $$ 3. Go all out and get the AccAir E-level system. $$$$$$$ I list these this way because these are all kits I can buy since I know nothing about air ride. So I guess what I'm trying to find out as you step up in systems you step up in price. Is the E level worth all the extra money on a ride that's not laying frame.
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
Re: Air Managment
I had a basic air management setup......it sucked for a truck that driven daily. You cant go wrong with accuair its the best !! If it was not for there e level system the old burb would be back on coils .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Re: Air Managment
Here is the old burb with 2000lb of concrete bags in the back. I did only have to drive 5 miles with this load Turn the key a drive. Perfect camber and caster every time
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Air Managment
Kevin,... member way2lo2 can set you up with a "manual" air ride system.
I have this in my '61 Belair. It would be my choice before I would run 8 individual parker style valves and a switch box. But Accuair really is the sh*t. Just depends on how much you want to spend.
#5 | |
Re: Air Managment
| Bookmarks |
