Look what I found. This truck is such a hack job.
Diggin The SquareLife
Re: Look what I found. This truck is such a hack job.
What makes this a hack job?
Exactly the same thing I thought.
Yes, that's not great. But it could have happened to anyone of us at any time.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I doubt it mounted to the bed factory
1973 C20, 350/350 |
You can see the normal mount hole further behind the shock.
It's kinda hard to tell by the pic, but it does look like it's mounted to the bed floor.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
Ok and? This is nothing new to our year trucks man....
I know the pieces fit
I think it's just broke free. It looks like it's rubbing the bottom of the bed.
Looks like he's dealing with several issues at once on that truck and it's just frustration boiling up. Hang in there and take one at a time, you'll get it buttoned up eventually.
If it makes you feel any better I imagine most guys here have endured fixing up some dumb crap done by previous owners.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you. |
#10 | |
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
Not hack. Just broken off the frame. Common problem on the rear shocks.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14, |
#12 | |
Thanks- Ian Last edited by hey its me; 02-26-2016 at 11:42 PM. |
#13 |
If you're willing to spend the money I'd go for Bilsteins. They're around $100 each, online Napa doesn't list em but OReilly does. There are reasonable cheaper options too, but I'm in the buy once cry once camp.
1973 C20, 350/350 |
#14 |
You do have to be careful.... and sometimes lucky when picking up an old truck. And yes, there are "Hacks" out there. I bought an 85 a few years back, and decided to check the brakes first thing. Had a hard time pulling the rear drums off. Discovered the rear axle seals were leaking, and the gear oil caused the brake linings to swell. Rather than repair the seals/brakes properly, the previous owner forced the shoes "tighter" (probably with a large c clamp) and tack welded them to the backing plate! That's what I call a "Hack"!
#15 |
I had a "70" el camino with a 72 front clip that had the worst brakes that I have ever felt, after poking around under the dash, their was a bungee cord holding up the brake pedal... I was speechless... and angry.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() Last edited by Matt Man; 02-29-2016 at 01:43 AM. |
#16 |
How about the 1/4-20 bolt in the motor mount on my new (to me) truck, or the exhaust 'mounted' with bailing wire, etc,etc. The list goes on and on. Hacks are everywhere, it's up to guys like us to make them right.
#17 |
That looks factory next to the hack jobs i have seen in the mini truck world,Or the favorite one was a donk they welded scrap metal on top the cast iron spindle for a lift.
#18 | ||
#19 |
Google s10 forum hack jobs and have nightmares trust me lol.
