Old 02-26-2016, 09:37 PM   #1
inkfamous13
Need options for front end upgrade for 1966 c20.
Trying to upgrade this 66 c20 i got. Dont really want to 5 lug swap it. Would do disk brake 71-72 crossmember swap. Or 73-86 c10. But options for keeping it 8 lug are what? Any help or info is greatly appreciated. Since you cant swap out lower control arms cuz of the way these mount. Ive been seeing online guys saying theres a spindle swap from 94-99? Idk that uses a 3/4 ton lower ball joint? If this is a option what would i need to do a disk brake 3/4 ton spindle swap and what booster? Also what rear ends work? Theres a guy who has a full floating 98 8 lug with 3.73 gears. This sounds way better than my 4.99 gears now LMAO its bad. How difficult is it to swap in? Or should i just do a 5 lug swap. Im going to do this paint it and resale it. So im looking for what is more liked as far as c20 wise? I allways have bought and keep original. But this front end is wobbly and brakes are sketchy and rear is loose. Other than that its a solid fully optioned 66 c20? Ideas, help,info,direction all appreciated. Thanks.
inkfamous13 is offline   Reply With Quote
Old 02-26-2016, 09:47 PM   #2
akaupp
Re: Need options for front end upgrade for 1966 c20.
http://67-72chevytrucks.com/vboard/s...d.php?t=357610
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline   Reply With Quote
Old 02-26-2016, 10:08 PM   #3
chevy.c10
chevy.c10's Avatar
Originally Posted by akaupp View Post
In the link he at around 9 minutes in he talks about taking the whole front crossmember and everything from a late model suburban that bolts in with no modification. I believe he is talking about the OBS chevy body style '88-'98 which is what I think your suffice for what your looking for.
https://www.youtube.com/watch?v=D4yJWB8JLUA
He talks about the same thing on a different truck to if you interested to know more.
https://www.youtube.com/watch?v=zDXzNLufVv0
chevy.c10 is offline   Reply With Quote
Old 02-27-2016, 02:57 AM   #4
akaupp
In the second video he mentions using a 1991 Suburban, which would be the same as 73-87 truck.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
Old 02-27-2016, 04:44 AM   #5
chevy.c10
chevy.c10's Avatar
No I don't believe so, I think that only includes OBS style vehicles 88-98.
Old 02-27-2016, 11:24 AM   #6
akaupp
1991 was the last year of the square body for Suburbans.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
Old 02-27-2016, 11:19 PM   #7
Mathew21
Mathew21's Avatar
Yep, My crossmember is my 66 is out of a 1991 square body Suburban.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 02-28-2016, 04:19 PM   #8
chevy.c10
chevy.c10's Avatar
Didn't know that. So let me ask can you just take a crossmember and all the bells and whistles from a 73-87 truck an it should bolt in with little to no modification?
Old 02-28-2016, 04:43 PM   #9
akaupp
I haven't personally done it, but from what I understand, you will have to drill 1 hole and elongate 1 hole per side.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
Old 02-28-2016, 05:29 PM   #10
Vinceg
Vinceg's Avatar
I was very surprised at how easy it was to swap the front crossmember from the newer truck. You can bolt it in place and get the other holes lined up on the side of the frame rails. The idler arm will need to be lined up and holes drilled. Also the sway bar to the front of the frame rails if your putting a sway bar in that is. A bracket for the power steering and Bob's your uncle! I haven't had mine in to get an alignment yet but it's all in there.
Vinceg is offline   Reply With Quote
Old 02-28-2016, 06:51 PM   #11
Mathew21
Mathew21's Avatar
Here's a good thread about it.
http://www.67-72chevytrucks.com/vboa...d.php?t=357610
Old 02-28-2016, 10:57 PM   #12
inkfamous13
Does anyone know if 1990 chevy van 20 with 5 lug disks is the same as up to 91 burbs meaning it will swap into my 66c20? Ive looked far and wide all over the net. Cant find an answer. This crossmember on the 1990 van looks just like all the 73-85 c10 crossmember swaps to me? But i cant deal with the hard work of removing it if it wont 100 percent work. Its half off and the junk yard is closing tomorrow at 5 for good so might beable to get them to just chop off frame at end of day. If anyone can help me out id appreciate it. If not gotta pay more and still need rear end swap.
