Old 02-27-2016, 08:10 AM   #1
hogfarm
Whell Tubs
I am getting to the end of my build of my 1958 chevy short bed fleetside.I need to widen the rear wheel tubs by 9",I can do the work but it would be a lot.is there anywhere I could buy new wide tubs that look stock?
hogfarm is offline   Reply With Quote
Old 02-27-2016, 11:35 AM   #2
dsraven
Re: Whell Tubs
lots of guys use trailer fenders. check a trailer supply outfit. some come filled in on one side and open on one side. worst case scenario you could fill one side in yourself and cut the lip off the other side where it would mount up to the box.
Old 02-27-2016, 11:44 AM   #3
hogfarm
Old 02-27-2016, 11:45 AM   #4
hogfarm
Old 02-27-2016, 11:46 AM   #5
hogfarm
Re: Whell Tubs
I am trying to keep stock shape. Just wider. I have split the old tubs
Old 02-27-2016, 12:04 PM   #6
dsraven
Re: Whell Tubs
a sheet metal shop should be able to bend you up a "U" shaped channel you could attach to your originals and that way you retain some strength over the extra wide tubs. it would also look like it was made like that and wouldn't have to be welded in at the joints because the "arms" of the U would become the attachment flange against the old tubs and the box sides so you wouldn't see themunless you looked up inside yhe wheel opening. would that work? screwed or rivetted together (or welded if you wanted).
Old 02-27-2016, 03:00 PM   #7
Rude Dude
Rude Dude's Avatar
Re: Whell Tubs
These are not mine wheel tubs for 58 or 59.
http://phoenix.craigslist.org/wvl/pts/5433096682.html
Rude Dude is offline   Reply With Quote
Old 03-14-2016, 07:21 AM   #8
hogfarm
Re: Whell Tubs
I decided to just cut the tubs and widen them,easy just took a couple hours
