Old 02-27-2016, 01:41 PM   #1
71swb4x4
71swb4x4's Avatar
New gas tank u bolt
There is hope for all of us. I didn't have the skills to make this before today. Yesterday I bought a piece of all thread rod and broke it every time I tried to get a 90 degree bend in it.
Today I bought a piece of 3/8" cold rolled steel (36" rod), bent the 90's, and cut my own threads. I started with a $30 tap and die set from the farm supply store (the nicest one they had), got frustrated with that and went to Car Quest and bought a $150 tap and die set. With the good die I had these threads cut in less time then I spent trying to get the cheap die started. I probably used way more cutting oil than needed but I didn't want to mess this piece up.
All in today, I had about an hour into making this. Had the farm supply store had a quality tap and die set I could have made this faster.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-27-2016, 04:05 PM   #2
tjsblazer
tjsblazer's Avatar
Re: New gas tank u bolt
I had to make one for my build also. Basically the same way. Cold rolled rod. Make the bends and then cut the threads.
Looks good!
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 07-01-2016, 04:18 PM   #3
jjzepplin
jjzepplin's Avatar
Where does this go?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-01-2016, 09:06 PM   #4
tjsblazer
tjsblazer's Avatar
It drops down through the oblong holes in the rh lower frame rail. The rear oblong hole is in line with the rearward spring hanger / shackle. It is used to snug up the factory fuel tank straps.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-01-2016, 09:11 PM   #5
tjsblazer
tjsblazer's Avatar
You can see it installed in this picture.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-02-2016, 05:02 AM   #6
jjzepplin
jjzepplin's Avatar
Is there one on both sides?
Old 07-02-2016, 08:55 AM   #7
71swb4x4
71swb4x4's Avatar
No. The straps have a hook on the other side that goes into the frame hole.
I haven't seen any installed on the right side, all of the ones I have seen have been installed on the left side. It's not going to hurt anything, just mentioning what I have seen originally.
Old 07-02-2016, 09:28 AM   #8
69-72
69-72's Avatar
If you want to take it a step further, the last ones I made I decided to use stainless steel. You just need to make sure to get the correct grade of stainless, I forget what it is but there is one grade that allows for easier threading.
I would suggest cutting the threads first as the die holder arms may interfere with the other side if it is bent first. Also don't cut the rod to the exact length first, leave a little extra and trim as needed as the final step.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 07-02-2016, 09:31 AM   #9
jjzepplin
jjzepplin's Avatar
That makes good sense. My straps had holes on both sides. Must have been aftermarket. It was a poly tank. Sure would have been nice have these instead of the bolts I used. Anyone making these for us?
Old 07-02-2016, 09:56 AM   #10
69-72
69-72's Avatar
Speaking for myself, If I could ever figure out how to do threading on my lathe it would be a cinch to produce them but the labour in threading is just so intensive the bolts would cost a fortune.
Old 07-02-2016, 10:11 AM   #11
jjzepplin
jjzepplin's Avatar
What is the total length that I would need to start with? 3/8x16 threads?
Old 07-02-2016, 01:31 PM   #12
tjsblazer
tjsblazer's Avatar
You know I debated Rh or Lh side. Either way you're right they fit the same. Mine was Rh side and it appeared original but you never know. My little bit of googling showed them on the right. It may be another one of those inconsistencies from the factory.
As far as dimensions. Read this thread.
http://67-72chevytrucks.com/vboard/s...ghlight=u+bolt
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
