Old 02-27-2016, 05:59 PM   #1
57larry
Had my van tilt redone
last year while on vacation in FLA. I bought a tilt column that I found on the local Craigslist. turned out to be a van tilt. on this board I found fellow member 70SHORTFLEET. sent my tilt to him to be rebuilt. he shorten the shaft, painted the column and completely rebuilt the column. his workmanship is OUTSTANDING! I couldn't be happier. and to top it off, he shipped it to me in a heavy duty box with wooden block ends with a hole drilled for both end shafts.
thank you Les for a piece of art. Larry
57larry is offline   Reply With Quote
Old 02-27-2016, 09:16 PM   #2
BCOWANWHEELS
Re: Had my van tilt redone
what did it cost you ?
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 02-28-2016, 10:02 AM   #3
Procurement_man
Procurement_man's Avatar
I used Les as well. Top shelf service indeed.
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel
Procurement_man is offline   Reply With Quote
Old 02-28-2016, 10:47 AM   #4
hugger6933
I bought a cluster from Les, it was really nice except for a small problem with the speedo. He told me to send it to him I never have even touched the truck since then but I would sure buy from him again and highly recommend him to anyone needing that type of stuff done.
When I bought the cluster from him I didn't know he was on the board so that did not figure in the deal. Top shelf guy, Great work.
hugger6933 is offline   Reply With Quote
Old 02-28-2016, 11:11 AM   #5
chiefcfd
chiefcfd's Avatar
Having rebuilt my own tilt, it is much more involved than people realize. I have around $450 in mine including the tilt I purchased at a swap meet. The problem I found was locating the parts I wanted to replace. I had to source multiple vendors as I couldn't find a one stop shop for this. I would do it again but you need patience and some specialty tools. The members on the board that do this are certainly not over charging anyone.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 02-28-2016, 03:59 PM   #6
BCOWANWHEELS
come on out with the price............
Old 02-28-2016, 09:37 PM   #7
57larry
price depends on the condition of your core. ask 70shortfleet
