02-28-2016, 08:24 AM | #1 |
Rumbling when cruising
Hello,
My 70 c-20 is making a rumbling noise. At first it was occurring when going about 55+ mph and not that noticeable. Gradually getting worse. I can feel it in steering wheel. Would this be some kind of bearing? Serge
General Contrucktor |
02-28-2016, 08:43 AM | #2 |
Re: Rumbling when cruising
I'd be changing those bearings , Can you feel it when turning or does it get worse ?
On the lighter side I usually try to get that Rumbling sound going down the road
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
02-29-2016, 09:49 AM | #3 | |
Any thoughts on carrier bearing. I had that replaced couple years ago with a 15$ one form Truck Shop catalog. Good point on rumbling sound.
02-29-2016, 12:32 PM | #4 |
Yeah, I'd be pulling those hubs asap and check them bearings before they "Weld"them selves to your spindles, that's a monster you don't want, trust me.
New bearings/seals/re-pack with a good high temperature wheel bearing grease, better to do it all at the same time. Ben |
02-29-2016, 12:50 PM | #5 |
Divorced .....WITH KIDS
I had same problem . Checked rear end , drive shaft . Never could figure out problem , until front center cap fell off . Bearing was shredded .
1969 GMC SWB 1975 Chevy Malibu 80k 1963 Ford Galaxie 63k (inherited) 2005 Nissan Armada (wife's idea) |
03-01-2016, 10:18 AM | #6 |
Okay! I guess it's time to learn about replacing and repacking wheel bearings.
Is this something a novice can attempt or should I go to a professional? Thanks for your time.
03-01-2016, 10:54 AM | #7 |
it's easy use the search engine above for threads on replacing them or just Youtube it . use good grease and have plenty of rags repacking bearings by hand is fun !
03-01-2016, 05:23 PM | #8 | |
Thanks.
