Help with vin number?????
Where to find the vin numbers on a 54 chevy truck and ????? Do the numbers that are on the plate between the driver door and the post must match the numbers on the license certificate? or which number is the one that must match the license certificate? How can I verify ir the engine is the original, factory one for the truck?
Re: Help with vin number?????
Number on the door post tag should match the title and registration. On AD trucks there is no number on the frame, the States usually used the engine number. So if the Vin matches the engine and title life is good. But if the engine was replaced and the title not adjusted when it was done you get to go play with the DMV. Some times if the engine was replaced the State assigned a VIN with a separate tag on door jamb or firewall.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#4 | |
