Old 02-28-2016, 11:46 AM   #1
Thundarr
Thundarr's Avatar
Heater Control
I've got a stock setup with AC and the temperature control never quite seems to completely shut off the heater valve. Similarly the AC system checks out, but never quite gets cold. It seems like the AC is fighting the heater.
I have already replaced the Heater valve and check to make sure it is getting vacuum to operate. My next step might be to change out the panel control to make sure it is passing on the full vacuum to the valve. I guess I could just put a manual ball-valve uder the hood to shut down the hot antifreeze to the heater core in the warmer months.
1971 GMC C15 Sierra Grande SWB
1972 Chevy C10 Custom Deluxe LWB
2018 GMC Yukon Denali
Thundarr is offline   Reply With Quote
Old 02-28-2016, 12:31 PM   #2
Wrenchbender Ret
Re: Heater Control
There is a housing under the dash with a flapper in it. It is notorious for the flapper coming loose. That might be the problem or part of it.
Wrenchbender Ret is offline   Reply With Quote
Old 02-28-2016, 12:33 PM   #3
Grumpy old man
Grumpy old man's Avatar
Re: Heater Control
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 02-28-2016, 03:33 PM   #4
Thundarr
Thundarr's Avatar
Re: Heater Control
Thanks, I'll check the diagram.
Old 02-28-2016, 04:47 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Re: Heater Control
Also may have a mouse nest in it keeping the diverter door from working....
LockDoc
Leon
Old 02-28-2016, 07:44 PM   #6
Thundarr
Thundarr's Avatar
Re: Heater Control
Got it fixed.
Let me explain for some other future poor soul, who messed something up while trying to fix something simple.
After changing out all the old air vent lines, I re-positioned the cable for floor/defrost diverter controls with too much bend. I straightened out the path so now the lever on the control slide panel had its full travel. Because it wasn't able get to its intended end, it kept the temperature control from fully extending so it wasn't fully closing the vacuum line to the heater control valve.
In essence, it wouldn't let the valve shut off the flow of hot water through the core. So in a way, it was a control issue.
Many thanks!
Thundar
Old 02-29-2016, 09:39 AM   #7
snipescastle2
snipescastle2's Avatar
Talking Re: Heater Control
I've heard that many of those water control valves never close fully, even new ones out of the box....might be a good move to add a small ball valve to shut off the flow all together.
Ben
snipescastle2 is offline   Reply With Quote
Old 02-29-2016, 05:45 PM   #8
Thundarr
Thundarr's Avatar
Re: Heater Control
Ben
You are absolutely correct. I did a wider search and found Pantera and Corvette club forums that recommend this with vacuum operated heater valves. Mine is better now, but I am going to set up the ball valve shutoff for the hot summer months in Texas. I need every bit of cooling I can get out of that stock AC.
I just picked up this same setup at the hardware store.
Some of their members worry about adding more location to leak coolant so they use clamps to simply pinch off the feed hose to the heater core.
Thanks again to all.
Old 03-03-2016, 12:05 AM   #9
Thundarr
Thundarr's Avatar
Re: Heater Control
Just got the shutoff installed and the difference in the AC is absolutely amazing. The air used to be cool and now it is COLD.
I highly recommend this to anyone in a hotter climate.
Old 03-03-2016, 12:15 AM   #10
89AKurt
89AKurt's Avatar
Re: Heater Control
LockDoc
OMG, you too? I just took a clump of floor insulation and kleenex out the other day. LOL
I have a broken lever, and other issues to work on, project #89.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 03-03-2016, 12:29 AM   #11
LockDoc
LockDoc's Avatar
Re: Heater Control
Yup, Must have been a mouse motel in mine....
LockDoc
Leon
Old 03-03-2016, 02:09 AM   #12
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Heater Control
I've been running a manual shut off in my 71 for 20 some years now for the summer months. It's one of the best idea's for the AC.
Another great idea is closing off the outside cowl vent totally and having the passenger side kick panel manually operated to cool the cab even more. I can get 38-40* temps on 100* days here in SC.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
