![]() Join Date: Sep 2013
What's this???
I know this wire comes from my block to my alternator. It had a plastic cover over it that crumbled and this was inside. What type link or connector was/is this?
Isnt that wire a little small for my alt?
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
![]() Join Date: Dec 2013
Re: What's this???
Fusible link .
![]() Here's a link you don't need 100' but it gives you the info on what it is and does . http://www.qualitydist.net/pico-8126s.html Don't increase the size of the wire Don't use a fuse they are fast burn when a fusible link is a slow(overload) burn Don't change the length Don't use anything else other than the original style and gauge it's ment to blow BEFORE it burns up anything else . Most any auto parts stores will have them in stock
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 02-28-2016 at 12:27 PM. |
Re: What's this???
Grump is right. It is a smaller wire that will burn out from a direct short in a few seconds. Instead of burning out the complete harness. That connector should be insulated or it might burn the link out sooner than necessary.
Re: What's this???
thx guys...just gonna update it all...appreciate it again..
Maybe cover it with some heat shrink tubing.
Ben ![]() |
Re: What's this???
Wait wait wait, someone is confused. If he's talking about the metal piece and that's a fusible link, then I'm confused. If he's talking about the wire then other people are confused.
I have no idea what the metal part is. The WIRE is a fusible link, 16 gauge, as described.
Re: What's this???
These trucks originally have an actual teeny inline fuse in both front corners for fuseable links. They tend to corrode and get crusty after all the years. If they blow they are usually stuck in there and the sockets are too crappy to clean well, so a length of fusable link gets spliced in
