Old 09-23-2003, 01:25 PM   #1
Beau Flecks
Beau Flecks's Avatar
Wanted, 1970 4X4 drive shaft
I need a main drive shaft for a 1970 4X4 long bed auto truck. Located in central Missouri.
Beau Flecks is offline   Reply With Quote
Old 09-24-2003, 11:10 PM   #2
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Do you need one for a 1/2 or 3/4 ton? What transfer case & trans do you have?
jeffspower is offline   Reply With Quote
Old 09-25-2003, 12:35 PM   #3
Beau Flecks
It's a 1/2 ton with a turbo 350, but i'm not sure which transfer case I have. I think it's a 203. How can I tell for sure?
Old 09-25-2003, 12:48 PM   #4
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
203's have hi & low loc, and hi & low "unlocked". 205's have just 2hi, 4hi & 4low.
Old 09-25-2003, 02:25 PM   #5
Beau Flecks
Sounds like I have the 205 case then. I have manual lockouts on the hubs and only one shift lever. The pattern is dash- 4lo-N-2hi-4hi- seat. I usually only work on old cars and race cars. I don't know that much about the old trucks. This truck is for sale by the way.
Old 10-10-2003, 11:30 AM   #6
Beau Flecks
Does anyone have a drive shaft or know what kind I need to get?
Old 10-12-2003, 01:09 PM   #7
jerry moss
Born Psycho
jerry moss's Avatar
Beau,
the original driveshaft for your truck is a huge 4inch tube. you're better of having a new one built out of smaller diameter tubing, in my opinion. you stated earlier that you mess around with race cars so i'm sure your driveline shop would give you a good deal on a custom built unit. if you're set on a oem shaft, try bill at vintage chevy truck in fremont calif, 510-651-5874. by the way, if your truck has the 350/205 combo in it, any 70-72 longbed 1/2 ton 4x4 shaft will fit.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 10-13-2003, 03:44 PM   #8
Beau Flecks
Thanks for the info. It'll probably be much easier to just have one made.
