fuse block missing?
Hey guys, out working on my 59 3100 today. I was looking for a fuse block up under the dash? Wasn't one there? Is this correct from the factory? Even my 55 sedan had a small 6 or 8 fuse block.
Thanks Tod |
Re: fuse block missing?
I have an original factory one in great condition laying on my parts shelf.
It was mounted behind the voltage regulator on the inside of the firewall forward of the brake handle. email me. hillenger512@cox.net
http://http://67-72chevytrucks.com/v...d.php?t=489721 Last edited by Coupeguy2001; 03-03-2016 at 10:11 PM. |
It was an optional item in 55, 56, 57, and 58. Can't say about 59.
I did some Google research. Seems that it was option in 59 as well. Thanks guys!
ttt
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
I hunted all over my 59, checked in the assembly manual, and never did find it. Maybe it was optional is the correct answer, I believe.
It would be forward of the park brake handle and above the floor mat on the LH side of the vertical part of the firewall. Get all that?
55-59 trucks had optional everything
![]() most of the overload protection was built into the headlight switch the switch has 2 bi-metal points style overload autoreset breakers as shown in the picture below one side protected the headlights; if your headlights ever flash on hi beam, this is the overload breaking, cooling and closing the other side of the switch protected all the other light circuits on the truck; brake, tail and (optional) blinkers the small fuse was for the dash lights, as the headlight switch had the rheostat built in for dimming them the only trucks i've seen with the small fuse panel on had the optional electric wipers typically the optional heater and optional radio had in line fuses when the wipers were added the fuse panel went in a basic truck without the heater or radio and electric wipers had no fuses, other than the one on the headlight switch ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Thanks to all that responded. I don't need a fuse block, jylust surprised these trucks didn't come with them standard I do have the fuse in my light switch though. Thanks guys.....I'm learning so much thanks to this forum.
