Old 02-28-2016, 03:48 PM   #1
Isaiah92260
Isaiah92260's Avatar
Broken Water Neck on my 250.. Can't find part! :(
I can't find the Water outlet/Flange/Filler Neck.... Which ever it's called on my straight 6! It's the part that the Temp Gauge sensor goes into, I was replacing the sensor and over tighten like a dummy, I was tourqing it down to 25 lbs and it flange cracked at 20 ..... Anyways I can't find the part on eBay, or on any of the after market websites... I looked for motor on Craig's light in my Palm Springs area and no one has it..... Does anyone on this forum know where I can find the part? Or is there a bypass part alternative that I could use? The thermostat housing keeps popping up online and that's not what I'm looking for, I don't think anyone remakes it :/ thanks for reading and helping in advance
Isaiah92260 is offline   Reply With Quote
Old 02-28-2016, 04:08 PM   #2
padresag
Re: Broken Water Neck on my 250.. Can't find part! :(
sometimes when you do not know what it is, perhaps one should post a picture.
they are not called sensors but sending units at that place in time. some had the sending unit mounted in the side of the head.. is yours mounted in that neck piece between the front of the cylinder head and the piece where the rad hose fits(top of the thermostat housing). the thermostat actually sits down in the piece that you screwed up?
ron
padresag is offline   Reply With Quote
Old 02-28-2016, 04:17 PM   #3
DPowers
DPowers's Avatar
this it?
DPowers is offline   Reply With Quote
Old 02-28-2016, 04:31 PM   #4
Isaiah92260
Originally Posted by DPowers View Post
this it?
Yes that's it! but mine has the threaded hole on the drivers side, not sure if that makes a difference how how it bolts to the head.... Is there any manufacturers that re makes that neck?
Old 02-28-2016, 04:31 PM   #5
Isaiah92260
ron
Yes that's the part your are describing.... I'll take a picture when I get home today
Old 02-28-2016, 05:25 PM   #6
Isaiah92260
The neck... Do they make these any where?
Old 02-28-2016, 05:34 PM   #7
mehoff400
http://mrhotrod6.myshopify.com/produ...ant=1142526369
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 02-28-2016, 05:51 PM   #8
Lugnutz65
Lugnutz65's Avatar
I have an extra that I saved. I'll send you a PM.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 02-28-2016, 05:54 PM   #9
Isaiah92260
Okay thanks buddy, waiting for your pm
Old 02-28-2016, 05:56 PM   #10
padresag
that is the heater hose outlet you are looking at. if you look a little closer you will see the temp sender on the other side
ron
