Old 02-28-2016, 05:30 PM   #1
mikey531
mikey531's Avatar
Interior after tank removal
I would like some ideas on how to finish off my interior after moving the tank to the rear. Or where to look?
Thank
mikey531 is offline   Reply With Quote
Old 02-28-2016, 06:29 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Interior after tank removal
New carpet kit from ACC and add the extra panel to cover the back wall . the new carpet can be ordered to cover the floor all the way to the back wall of the cab after removing your tank they also make a rear panel .
Auto Custom Carpets
https://www.accmats.com/
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 02-28-2016, 07:15 PM   #3
mikey531
mikey531's Avatar
Thanks Do you have any pictures?
Old 02-28-2016, 09:33 PM   #4
57larry
Auto Custom Carpets
that's the way I did it
57larry is offline   Reply With Quote
Old 02-29-2016, 01:37 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Interior after tank removal
May I suggest you look over in the truck audio section. Even if you don't plan on a speaker box there are some great idea's in the section for how to do the backside.
http://67-72chevytrucks.com/vboard/f...ysprune=&f=111
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
