HVAC Questions
I got my new heater/AC controls because one of the levers on mine was broken. I started labeling everything and unhooking the cables, wiring, and vacuum lines and realized something odd. The cable that goes behind the glove box had a really sharp bend in it that wouldn't let the cable move freely. This (coincidentally) was the same cable the broken lever was connected to. So it would seem at some point someone either crossed up the cables or installed a cable much too short to function properly. I know thats not the question but it lead me to start looking at the rest of the setup to make sure it looked correct.
Then I realized after hooking everything back up and checking it out that the vacuum setup seemed odd. So here are the questions: The top lever on the front of the AC/heater controls from left to right says INSIDE - AIR - OUTSIDE - DEFROST #1 When the top lever is all the way to the left (on the "INSIDE" mark) the vent on the passenger side opens. Shouldn't the vent open when the top lever is on "OUTSIDE" and not "INSIDE"? #2 The vacuum switch on top of the heater/AC control only has (2) lines coming off of it on ports #2 and #3. Port #1 is blocked off. Is that correct? #3 With the top lever all the way to the left I can hear a faint sound of a vacuum leak coming from that switch. It doesn't seem to affect anything and I can only hear when I am under the dash. Is that normal? Thanks for any help or advice you can give. Jimmie
1972 K-20 Custom Camper 1971 K2500 Custom Camper (Sold) 2014 GMC 2500HD DMAX |
![]() Join Date: Apr 2012
Re: HVAC Questions
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
#3 | |
Old member
![]() Quote:
The outside flapper is closed when it's all the way to the left. The one under the cowl. That's the one that lets outside air into the cab. #2 The vacuum switch on top of the heater/AC control only has (2) lines coming off of it on ports #2 and #3. Port #1 is blocked off. Is that correct? ![]() If you have the 3 vacuum ports then it need to look like the picture above. No vacuum leak, if it's leaking you have a problem. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: HVAC Questions
Okay, thanks guys. That helps a lot. Does anyone have a part number or know where I can pick up a vacuum switch without having to buy the whole control assembly?
