Old 02-28-2016, 06:48 PM   #1
89AKurt
89AKurt's Avatar
Question: funky exhaust system opinions wanted
Previous owner had a new exhaust system installed, am thinking about a few things, need technical questions answered (?), and what might be a better option(s).
The heat riser valve (that what it's called?) is so rusty, it does not move easily, have in permanent open position. It starts fine, since I replaced the distributer and Holly carb.
(1) Do I really need it?
(2) Wouldn't it breathe better to have the 3" pipe go all the way from the header?
Again, they kept the original size pipe, that looks restrictive, obviously to squeeze past the starter. I read in other threads that headers running too close tend to fry the starter.
(3) Can't insulating tape, or a tacked on metal shield work?
Some of you may be shocked about this, they torch cut through the cross member.
(4) Should I be worried about this weakening the frame? Another thing that bugs me, is how the parking brake cables slide over the pipe, which could wear a hole eventually, and the pipe is rubbing on cut hole.
(5) Is this a good way to have more ground clearance?
I'm not interesting is restoring to original, but I do want to improve whenever possible. Would like at least to have 3" pipe to the header. Also have a weird desire to have the pipe terminate before the rear wheel, maybe on the driver side, just so I can enjoy the sound (a little different than the whiney whoosh of my MINI). LOL
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 02-28-2016, 06:59 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Question: funky exhaust system opinions wanted
Thats a pretty butchered looking exhaust , buy a heat shield from summit for your starter then take it to a decent muffler shop an have them install a 2 1/2 inch system and remove the heat riser , that will handle any street engine also the cut thru cross member was to keep the system up high and won't hurt anything. A real muffler shop will probably install your heat shield for you while it's on the lift .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 02-28-2016, 07:21 PM   #3
89AKurt
89AKurt's Avatar
LOL The guy I got the truck from said his grandpa half-assed everything.
Thank you!
1968 Long Bed
Old 02-28-2016, 11:22 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Question: funky exhaust system opinions wanted
one thing to consider when going with larger diameter pipe, you will kill the low end torque on a stock small block. a gas motor needs some back pressure unless you're running a big cam and lots of horsepower. i get people all the time thinking big is better but with a fairly stock motor it aint so.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 02-29-2016, 12:25 AM   #5
Lattimer
Lattimer's Avatar
The pass through the crossmember is pretty typical for lowered trucks. Most people weld in a pice of steel pipe where they make the hole to reinforce the crossmember.
Otherwise, what you have there is a pretty hacked up mess. I'd take it to a reputable shop and have them do it all over in 2-1/2" pipe.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 02-29-2016, 01:22 AM   #6
89AKurt
89AKurt's Avatar
Thanks Jerry Moss and Lattimer. I see a consensus on hack job and 2 1/2" so far.
1968 Long Bed
Old 02-29-2016, 10:07 PM   #7
Jerry is right (this is what he does). I'd have dual 2 1/4" exhaust run. If you are staying with cramming it all in one pipe, then I'd go bigger. 1/4" is a lot more volume than most think.
Old 03-01-2016, 04:21 AM   #8
swamp rat
swamp rat's Avatar
Look at the chart on this page and one can quickly see that on a stock SBC engine anything over a dual 2 1/4 is not helping flow requirements.
Jerry Moss is correct on loosing torque, plus the back pressure helps aid in scavenging of the exhaust.
http://www.exhaustvideos.com/faq/how...pipe-diameter/
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-01-2016, 10:25 AM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
My 72 with a bone stock 350 and 350 trans had duals when I bought it. Someone had cobbled a dual exhaust system on it by cutting off the y pipe half way down and pinching it off. Then they just ran an exhaust pipe from the pass side exhaust manifold to the back of the truck and there were 2 different sized mufflers on it. I'm not sure what diameters of exhaust pipes were on the truck but they were different sizes with the pass side one being smaller than the drivers side. I had the whole system replaced with a pair of Dynomax Super Turbo's ( see link ) with an " H " pipe and 2 1/4 exhaust pipes running right to the back. The truck runs much better now and sounds ( to me ) like a V8 4bbl dual exhaust vehicle should sound.
http://www.dynomax.com/super-turbo-c...ffset-596.html
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-01-2016, 06:20 PM   #10
89AKurt
89AKurt's Avatar
Seeing that you have posted a billion times, appreciate the confirmation.
I like the idea of twice pipes, with a cross over. If I go all the way to the back, will be tempted to add flame thrower device. >:^O
1968 Long Bed
Old 03-01-2016, 08:44 PM   #11
cleszkie
cleszkie's Avatar
Also consider re-routing your fuel line away from the exhaust pipe, or placing a heat shield over it. Looks pretty close in that picture.
cleszkie is offline   Reply With Quote
Old 03-01-2016, 10:30 PM   #12
dmartin1
dmartin1's Avatar
im very guilty of butchering some exhaust myself in a pinch, but yes i would rip that out and route a fresh system.
Im just weird with exhaust though too,even though little to none will ever see it, just knowing its not symetrical or goobered drives me crazy.
best of luck!
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 03-02-2016, 01:33 PM   #13
89AKurt
89AKurt's Avatar
Oh heck ya! That's been project #88 for awhile. LOL That was much worse when the saddle tanks were installed, plan to put mechanical pump back on engine, and use metal fuel line for this section.
1968 Long Bed
Old 03-02-2016, 01:36 PM   #14
89AKurt
89AKurt's Avatar
Originally Posted by dmartin1 View Post
[...] even though little to none will ever see it, just knowing its not symetrical or goobered drives me crazy.
best of luck!
Understand! The longer run from driver's side joining together is a great reason to replace, thank you.
1968 Long Bed
Old 03-02-2016, 04:46 PM   #15
Step-Ed
Step-Ed's Avatar
I had the same rusty pipes, and not a logic route. I went to a shop and they make a rvs systeem in front of the wheels. Great sound and beter route.
Step-Ed is offline   Reply With Quote
Old 03-03-2016, 12:29 AM   #16
89AKurt
89AKurt's Avatar
Step-Ed: That looks nice! So no cross-over pipe?
1968 Long Bed
Old 03-03-2016, 01:56 AM   #17
Step-Ed
Step-Ed's Avatar
I don't think it will benefit the engine. It is a stock 350, not a performange engine. And I think it sound beter without it.
exhaust pipe
