02-28-2016, 07:26 PM | #1 |
Which headers don't bottom out
Hey guys, I'm kinda new to this so I. Swapping my turbo 400 for a Tremec TKO 5sd, I found out that i need headers to connect Zbar to rod.
So I need new headers, can sumbody tell me which headers will fit for 5 speed and not be lower then my frame. Truck is low already and going lower soon with air ride. Please help!!! Pics would be great to lol Thank you... |
02-28-2016, 10:37 PM | #2 |
Re: Which headers don't bottom out
I'm sorry I can't specify a current offering, but I have never bought a set of full-length headers that sat lower than the frame. Maybe dumb luck, because so many say theirs hang lower. From my experience, if you use '73-up application headers they hang lower. Maybe some header companies are listing their 73-87 headers as working on 67-72, because they sort of do. I have some Sanderson shorties for my little '67 later on. I thought center dumps didn't work on 2wds, but the member I got them from took them off his truck and said they cleared. I'm see. I also have a set of Headman Elite full headers I haven't tried. To clear the bell crank you need headers that #7 drops vertical or slighty forward. I know old names that worked, but it's been a while since I've done a 2wd with manual transmission and those companies aren't around...Cyclone, Blackjack, etc all worked well
02-29-2016, 02:36 AM | #3 |
Active Member
Hi there is a guy on the forum that Make special headers don't hang below the frame rails they are not cheap mine were stainless steel Coded $1000 look great fit great that was about 5 years ago
02-29-2016, 07:41 AM | #4 | |
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
02-29-2016, 09:04 AM | #5 |
You don't need to buy $1,000 custom headers. Someone will come along with an off the shelf header. This is a common problem on low manual trucks. The automatic guys just run 3/4 length. But those run right through the clutch linkage. My buddy neighbor Eddie built his '68, 4/6 drop, 4spd and tossed a set of old headers he had laying around and they run above the bottom of the frame. Frustrating. I asked what brand they were so I could offer help here and he said, "I dunno". so, just get a set of those
02-29-2016, 10:54 AM | #6 |
