02-29-2016, 02:05 PM | #1 |
best/cheapest 4 barrel intake 283
I have a 283 with a 1 barrel.....anone know of a decent replacement that doesn't break the bank and has the hole for oil filler?
Also need a stock style aircleaner for a 4 barrel too....thanks,
70chevytruck |
02-29-2016, 02:50 PM | #2 |
Re: best/cheapest 4 barrel intake 283
I would check Craigslist or salvage yards. If you can be patient, you should be able to get a stock intake or even a used Edelbrock or Holley for not a lot of money. I bought a used Edelbrock from a guy off CL for $35.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
02-29-2016, 03:02 PM | #3 |
Here's a thought, however.
The difference in power between a 2bbl and a 4bbl on a base 350 is 5 horsepower. They're rated at 250 with the 2bbl and 255 2ith the Q-jet. On the bigger 396 2bbl engines its tapped out at 265hp. So, if your engine isn't making more than 265hp, the 2-bbl is already plenty!
02-29-2016, 06:55 PM | #4 | |
70chevytruck |
02-29-2016, 07:06 PM | #5 |
Here's another thought ... the camshaft is likely for a 1 barrel. Therefore the engine will not make use of larger carb and 4-bbl intake.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
02-29-2016, 08:19 PM | #6 |
Please show pictures of the one barrel carb on your 283 small block.
( Just because it has one round hole on top doesn't make it a 1 barrel. I'd bet dollars to donuts that you have a two barrel Rochester ) |
02-29-2016, 08:30 PM | #7 |
BOHICA
no matter what you have. Summit has good cheap intakes under their brand. I got free edelbrock 1406 and put it on a summit intake and it woke up my 307. Of course the factory two barrel was in terrible shape though
Posted via Mobile Device. Last edited by BluTrukker; 02-29-2016 at 08:40 PM. |
02-29-2016, 09:08 PM | #8 |
Best running, most reliable, coldest-starting pre-fuel-injection vehicles I have ever owned where the Rochester (2GV?) 2-bbl carbs.
The -best- cold-start vehicle I've seen to date was a tie, but one of them was a 307 '68 GMC with a manual choke. The compression was low so maybe they crank faster in the cold too, but it always lit off in -40F. My '75 Monte 2bbl cold-started, not plugged in, at -44F, the coldest I've seen (wind chill doesn't affect metal once its ambient). The only reason I plugged it in was that the oil is like lard and its hard on them in that temperature! Do I sound oddly fond of 2 barrels for a guy that no longer owns any?
02-29-2016, 09:19 PM | #9 |
Totally agree, The rochester 2bbl carbs are some of the best running and easiest to tune carbs around. I have never heard of a 1 barrel carb on a v8.
If you are looking for more performance I would look for a good used 350 with a 4bbl intake/ cam already installed.
1971 Cheyenne Big Block Longhorn |
02-29-2016, 09:23 PM | #10 |
Just buy a used factory 4bbl intake. The 4bbl gets better mileage than the 2bbl on a small block, unless you run with secondaries open all the time. Consider the primary CFM compared to the full-time CFM of the 2bbl. Don't get too much carb for the motor and it will give the best mileage and power...when you need it
02-29-2016, 09:48 PM | #11 |
there are small base rochesters and large base rochesters, the small base is around 290cfm, the large base comes in 353cfm 380cfm 425cfm and 435cfm, so if you get a large base intake that 283 should really wake up, a Canadian truck 2bbl intake flows the best, it was used on street stock nascars for years
03-01-2016, 02:09 AM | #12 | |
03-02-2016, 12:35 AM | #13 |
keep it stock..........................
I BELIEVE IN JOHN 3:16 |
03-02-2016, 02:15 PM | #14 |
GM did use 1 barrels on the early SB in the bigger trks. they were like 165 hp but had a lot of low end torque. There are acouple over at the yard across the street. the small 2 bbl is about 20 hp more. the moter in my 63 is a 66 chevelle 2 bbl. rated at 195 hp. that's got the small 2bll. on it. I'm alittle shy on fuel around 4500 in high gear. If I was lookin for a little more I think I would go to the 1 1/2 inch flange 1 11/16 bore 2 bll. which flows around 425 cfm. up from the 300 I'm getten now. or probably the quadjet.
03-02-2016, 04:40 PM | #15 |
Certain Chevy cars also came so equipped. The 1-bbl 283 set up was very common in Checker Cabs too.
03-02-2016, 05:10 PM | #16 | |
then you have square flange "4 jets" I think 500 cfm and spredbore "quadrajets" around 750 cfm
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
03-02-2016, 09:35 PM | #17 |
I have a stock 283 4 barrel with the oil filler tube and the tab for the spring. It is in nice condition. $75.00, but the shipping would probably be a lot from here in Indiana
