![]() Join Date: Sep 2013
WTB. Ac heater flapper box
Looking for distribution box in cab ac truck.
![]() Join Date: Jun 2011
Re: WTB. Ac heater flapper box
I think I have one. Does it have the heater core in it or the plastic one? I'll have to find them tomorrow
![]() Join Date: Jun 2005
i have a good a/c diverter for $60 shipped. let me know if that works for you. thanks, brian
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
Thanks I'll take it...pm for payment
sent you a pm. this is what you need, correct?
"Trucks with Class"
I have a new one for $95 + $15 S/H.
Be careful of problems on used ones: The case warps if they get too hot and the shaft to the flapper door breaks loose, under the rubber, where you can't see it. Hold the door and try to move the shaft. It should be "tight" and not moving. |
Active Member
![]() Join Date: Feb 2009
If you flapper is just busted loose you can fix it for less than a dollar. Better than new.
72 Sierra Grande 2500 BB 72 Sierra 2500, 42K miles, factory buckets 72 Cheyenne 20 72 Chevy SWB, Factory BB, Leaf Spring |
Thanks Brian ..that's the part...hope the rubber is good
let me double check it before you send payment. will do that tonight. i know what frank is saying because i have another one that the flap broke from the shaft.
thanks!
here are some more pics. there are two chips, one on the oval tube and one where one of the 's' duct screws goes. rubber is good and shaft is not loose.
let me know if this works for you. thanks.
![]() ![]() Join Date: Feb 2009
How?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Nov 2012
I have one listed for sale.
see http://67-72chevytrucks.com/vboard/s...d.php?t=607498
Roger Koop |
