02-29-2016, 08:19 PM | #1 |
How to bleed transmission lines?
So I have a th400 and I just rebuilt the motor and installed a stall converter. I have a trans cooler built in to the radiator, as well as an auxiliary cooler. I'm wondering how to get the air out of the system once I get everything put together
02-29-2016, 08:21 PM | #2 |
Re: How to bleed transmission lines?
It will self bleed when you start the engine and run fluid through the trans.
02-29-2016, 08:33 PM | #3 |
Yep, just make sure the bottom ports on both coolers are intake. Top ports should exit the cooler.
'68 C10 SWB '85 K30 Blazer |
02-29-2016, 09:40 PM | #4 |
Post Whore
Not sure if your trans is fresh built but if it is you need to get a can of trans line flush to get all the old fluid out of the system.I do it every time I change trans fluid.
02-29-2016, 10:35 PM | #5 |
OT, that TH 400 is pretty tuff. All I have is an external cooler. 140K and shifts as smooth as always, and that's despite an occasion I hauled far too many building rocks......up hill ..........6x12 trailer and bed loaded.......Whoops.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-29-2016, 11:12 PM | #6 | |
I was thinking of having just one cooler, but I just put in a high rpm stall converter too, so I want to keep it nice and cool |
02-29-2016, 11:13 PM | #7 |
Thanks guys
Matt |
