Old 02-29-2016, 09:49 PM   #1
rsgt
rsgt's Avatar
Changing front coil springs
When you guys change your front springs do you undo the top or bottom ball joint? Which to you prefer. Thanks
rsgt is offline   Reply With Quote
Old 02-29-2016, 10:30 PM   #2
SoCoC10
SoCoC10's Avatar
Re: Changing front coil springs
I leave the spindle attached to the upper ball joint. Turn the castle but on the lower a few turns but still fully on the lower ball joints threads. Make sure you have the truck up high enough that the lower arms can swing way down to release the springs tension. Be safe and good luck.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 02-29-2016, 10:45 PM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
Neither. Rent., borrow, or buy a coil spring compressor.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-29-2016, 10:49 PM   #4
kwmech
I use a floor jack and release the lower joint.
Old 02-29-2016, 10:54 PM   #5
BigRed76
BigRed76's Avatar
Use a floor jack to support the lower control arm, unbolt the lower ball joint, then unbolt the shock from the lower control arm, then lower the control arm with the floor jack to take the pressure off of the coil spring.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-29-2016, 10:56 PM   #6
davepl
davepl's Avatar
Well, a couple of additional things:
- Heavy chain well bolted so the spring can't take off on you
- An internal spring compressor up the middle
- Floor jack under the control arm
- Truck still assembled so you have weight on the frame (tough job on a bare frame, done it)
Take springs seriously. One to the forehead will ruin your hole day. Actually it'd probably kill you but I'm being nice about it...
Never hurts to read and follow the shop manual. On my Pontiac they have a template for a lower control arm tool made from a 2x6 plank, and you need to make one to do the job!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-01-2016, 12:12 AM   #7
Benny-
What about removing the u bolts on the inside of te LCA? I've heard this could be an option?
1972 C/10 Cheyenne, Daily Driver. SOLD
1978 GMC K15 High Sierra.
Benny- is offline   Reply With Quote
Old 03-01-2016, 01:31 PM   #8
kwmech
Not necessary, with the spindle assy out of the way and the shock disconnected it will swing down enough to pull the spring out of the way
Old 03-01-2016, 04:15 PM   #9
hooverfish
hooverfish's Avatar
When you reinstall the spring, will you have to compress it to put it back in (when using stock springs) ??
Or can you just use the floor jack to reinstall the spring with stock ride height ??
Larry
84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles.
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 03-01-2016, 04:34 PM   #10
kwmech
Yes, that's what I've done for the last 30 years. It helps if you can get the jack as far outboard as you can...leverage. I get the jack between the coil pocket and the ball joint.
Old 03-01-2016, 08:14 PM   #11
hugger6933
I've framed a hundred or more later model truck but only a couple of the older ones so I don't know if this is a thing on them or not but Id advise you to take off the splash shield if there is even a chance it could get caught in the lower control arm as it is released. It will just tear the bottom of them right on out. Don't ask me how i learned this, well you shouldn't have to you can guess I tore a couple or more before doing that.
Please be alert there is lots of stored energy in those spring and they have a way of getting your attention and can mess you up. Jim
hugger6933 is offline   Reply With Quote
Old 03-01-2016, 08:28 PM   #12
69SCSS
69SCSS's Avatar
Yep, I always tie a ratchet strap around them so they can't fly away... I don't need a hole in my wall or me
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
