Old 02-29-2016, 10:43 PM   #1
Thanos
Thanos's Avatar
Cool My 72 longhorn dually project
Removed the D60 found it has a locker or that power lok or w/e. One wheel wont turn w/o the other.
Then realized how much beefier the AAM is over the D70HD
My 72 GMC longbed with 50k original miles. ARIZONA truck!
0 rust!
Under body going to paint soon.
Thanos is offline   Reply With Quote
Old 03-01-2016, 02:11 PM   #2
Thanos
Thanos's Avatar
Re: My 72 longhorn dually project
The AAM is less than a half inch off on each side (wider)
I'm guessing less than a half inch would require new perches... any other way around this? heh
Old 03-12-2016, 01:29 AM   #3
Thanos
Thanos's Avatar
Ordered 19.5's aluminum dually wheels, anybody ever done this size on a 72?
I may be in the wrong forum for this kind of stuff...
Old 03-12-2016, 08:31 AM   #4
hugger6933
There are a couple of one ton threads heavy with pics. they also have a few with 19.5's on them. You won't be disappointed with your choice. Jim
hugger6933 is offline   Reply With Quote
Old 03-12-2016, 12:37 PM   #5
Thanos
Thanos's Avatar
Clearances was the main thing, turning etc. Front offset is 0! Hate spacers...
Most fabricate their dually fenders since you can't buy them anymore?
Old 03-13-2016, 09:02 PM   #6
Thanos
Thanos's Avatar
So they sent me 19.5's dually set up... was supposed to get non dually front however they sent them anyway.
Now anybody have any input/experience on steel front dually adapters?
Old 03-14-2016, 10:20 PM   #7
Thanos
Thanos's Avatar
Replaced leaf spring bushings and decided on the D70 HD saving the AAM for later. BTW the D70 HD is a direct swap minus shock mounts.
Dropped the dually fronts ,getting the correct rims and just bought a 8.1 to replace the meh 454.
Dropped all fuel tanks don't care for the set up.
Old 03-17-2016, 10:19 PM   #8
Thanos
Thanos's Avatar
D70HD was a direct swap minus shock mounts. Later swap in the AAM 1150 with disc brakes.Helper springs for a cheap fix until I get a better set up and air bags.
Old 03-18-2016, 11:48 PM   #9
Thanos
Thanos's Avatar
Disappointing that Curt does not make a class V hitch anymore so guess this class V will do.
Surprising the hitch fit JUST right and looks good also.Just cleared the step bumper perfect.Next fuel tank and rims/tires.
