Change bezel lettering - anyone done it?
I'm in the process of installing my old Hickey Sidewinder winch onto my 1980 Suburban. In the course of rebuilding the winch last year, I realized that the remote control is a very simple momentary switch not unlike the fuel selector switch common on the dual tank trucks.
So of course I thought wouldn't it be cool to have a dash mounted switch to control the winch that appeared almost factory installed. What I would love to do is remove the lettering from the fuel switch bezel and change it to something similar to the photo I have attached. Removing the old lettering should be easy - time alone has almost taken care of that for me. Can anyone suggest some method I could accomplish myself to create the new lettering? I've found a font that is very similar to the GM fuel switch. I'm thinking of trying a decal making kit from Testors, but I'd be interested to hear if anyone else has tackled this in a different manner. Thanks in advance
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
Re: Change bezel lettering - anyone done it?
you could use a label maker. DYMO makes one and use the white on black tape
or a local sign shop could cut out letters for you. |
I hadn't thought of a label maker - thanks. That would solve the biggest problem of using an inkjet decal kit - no white ink.
find a trophy shop that has a lazer engraver. they can make an labeled overlay out of plastic.
any sign shop could make you little vinyl letters spelled out on contact paper!
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
I like this idea, and I'm going to check that out. I originally wanted the satisfaction of doing it myself, but depending upon the cost a trophy shop will likely give a more professional looking and possibly longer lasting result.
Art shops used to have something called Trans Art type. The letters were attached to a plastic sheet and you rubbed them off onto your desired surface.
