![]() Join Date: Jan 2001
Location: Katy, TX...but the love of my life resides in Dublin,OH.
Pneumatic Tilt Front end?
I saw the pneumatic fuel filler door Slammed67 posted on the other board and it got me thinking. Could I use air to lift my tilt front end? I am going to do a steel tilt instead of the fiberglass. I'm afraid that the electric actuators that would be needed to do the job might be kinda expensive...
I found these cylinders... I might not sure what size i would need to get. I think I know what kind...just not the bore size air cylinders Anybody know anything about this? |
Mike
Peterbuilts have used air cylinders to tilt thier hoods for years.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Fabricate till you "puke"
I cant help too much on cyl selection, but will say that if the "balance" is set up properly on the hinge, it shouldnt take too big a cyl to open that clip. the clip on my longhorn is 'armstrong"......I can lift it with 1 hand. The 1st ft up feels a little heavy, but after that it just floats up easy. I have hood pins /retainers between the 2 fender halves holding it closed. so I wanted a little weight to start the lift.....lots of wind under that booger at higher hyway speeds
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Try this catalog they have all the specs and I have been using a 2 1/2 " cylinder with 24" throw it will move 650 lbs at 150 psi. you might need a smaller cyl for a tilt and use a restricter in the inlet to slow down the speed air cyl move real quick lol.
www.mcmaster.com kman
New 89 chevy 1500 driver 72K20 rust bucket project stripped down to the frame engine rebuild started 71 Blazer - another procect |
Thanks for the replies. I am getting the picture... air may not be the route to go. if it is that light then I can use a single electric actuator.
Hey Crazy, Can you send me some pictures of your set up? darrylb@weissereng.com they would be much appreciated. |
I dont have any shots of the hinges, but there are a few shots of the clip.... http://community.webshots.com/user/hotrodhorn not real good shots of the internals, but you will see a little of the bracework. Its a little overkill, but the clip doesnt "dance" in the wind. crazyL
do a search on ebay for "Bimba cylinders" ... some of the best stuff out there in pneumatics ... last time I checked, there were several listings for them.
