Old 09-23-2003, 05:10 PM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
front end rebuild ... Part Numbers Please
I desperately need to rebuild my front end. I was looking at "kit" pricing. I want to do it all at once. I will list all the parts that are included in the kit from ECE. It's all Moog parts when available. So far its the most complete kit with all new parts. Can one of the vendors here offer the same collection. I would rather give money to a board member .. Mothertrucker, GMCPauls, TimChristian, Rick's ... or anyone that can put this together. Shipping to 10310 business address?
My truck is a 1971 C/10 with Power Steering and Power Disc Brakes
Upper Ball Joints............2
Lower Ball Joints............2
Inner Tie Rod Ends........2
Outer Tie Rod Ends........2
Tie Rod Sleeves.............2
Idler Arm......................1
Pitman Arm....................1
Upper Arm Shafts...........2
Lower Arm Shafts...........2
What I want above the kit is:
New Upper Arm Shaft Shims
Lower Arm Shaft U Bolts
Drag Link ( do I need one?)
Rich
1972 K5 Blazer CST Click HERE
Old 09-23-2003, 05:28 PM   #2
BIG ORANGE
BIG ORANGE's Avatar
I'm a Inventory Manager for Advance Auto Parts and we have all those items,maybe you have a store near by. At worst case it will be PDQ items meaning order today pick them up tomorrow!!!!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 09-23-2003, 08:38 PM   #3
MOTHERTRUCKERS
If you want the MOOG part numbers I have them here, your best bet is to get them locally to save shipping. An example of our MOOG parts K-6024 upper ball joint 24.00, K-6098 upper control arm shaft 36.00 etc.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-24-2003, 09:11 AM   #4
mcmlxix
mcmlxix's Avatar
If you could list the MOOG part numbers (and GM part numbers if you have them) it would be a good FAQ board list.
What about the shims and the u-bolts?
Does anyone make the drag link? Does it wear out like everything else? If its not that expensive I would like to replace it as well.
I am going to the local swap meet in NJ this weekend. Maybe I can collect the parts I need there... the part numbers woudl definitely help.
Rich
