Old 03-01-2016, 07:14 PM   #1
Mrturner1
What does this wire go to??
Wiring my alternator, wondering where the white wire goes that's not plugged in to anything
Mrturner1 is offline   Reply With Quote
Old 03-01-2016, 07:43 PM   #2
Tumbleweed1C4
Tumbleweed1C4's Avatar
Re: What does this wire go to??
I think that wire should go back to the cab, can't remember if it goes to the ignition switch directly or to the fuse block. In mine, there was a brown wire where the regulator was mounted on the radiator support that I mated this to. It went back to the cab.I think I have a picture of mine I can dig up if you need it.
Sleep safe in your beds because rough men stand ready in the night to visit violence on those who would do you harm
72 K5 Blazer
72 K10 SWB (in pieces under slow construction!)
72 K20
Tumbleweed1C4 is offline   Reply With Quote
Old 03-01-2016, 09:01 PM   #3
kwmech
If you have the original wiring for the alt. on the drivers side, it should be spliced into the brown wire in that loom. Comes from the ignition to excite the voltage regulator when starting up.
kwmech is online now   Reply With Quote
Old 03-01-2016, 09:30 PM   #4
swamp rat
swamp rat's Avatar
Look at this schematic on the bottom picture, it shows how to convert an externally regulated charging system (stock system) to an internally regulated system which is what you have, if you follow that connector on on position 1 on the alternator it ties into the brown wire, that wire routs to the harness connector on the firewall on the driver side. The brown wire on your truck may be routed across the top of the firewall to the passenger side of the engine. Humm maybe it got painted black?? LOL!.
http://67-72chevytrucks.com/vboard/s...09&postcount=9
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-01-2016, 09:46 PM   #5
Mrturner1
It sure did lol
