Old 03-01-2016, 08:27 PM   #1
Classic v6 GMC's
Classic v6 GMC's's Avatar
NOS 1967-72 V-8 Engine Mounts
NOS V-8 Engine Mounts for 67-72. They are marked as 292 but are V-8.
Asking $100+shipping
Price Drop $80+Shipping
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 03-02-2016, 02:10 AM   #2
In The Ten Ring
Re: NOS 1968-72 292 engine mounts
I am new to the game of the engine swap, how many of these do I need to put a 292 into my 250 truck?
In The Ten Ring is offline   Reply With Quote
Old 03-02-2016, 09:38 AM   #3
Grumpy old man
Grumpy old man's Avatar
The R (pass) side is hard to find . buy them as a set and sell your standards .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 03-02-2016, 10:08 AM   #4
Classic v6 GMC's
Can someone confirm these are 292? I thought they were but after looking at some other threads i'm not sure.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-02-2016, 10:13 AM   #5
Classic Bowties
Always on the hunt...
Just an FYI, I do not think the above pictured towers are for a 292 as listed. They look like the 2wd small block V-8 towers, we have a set of recently pulled 292 towers in the shop and can get a picture of them if needed. Mel
Classic Bowties is offline   Reply With Quote
Old 03-02-2016, 10:18 AM   #6
Classic Bowties
I think they were marked as 292 incorrectly at some point, I can take a picture of a 292 set if needed later this morning. Mel
Old 03-02-2016, 10:20 AM   #7
Classic v6 GMC's
If you could post a pic that would be great. The mounts were marked 292 when I got them so i'm not sure.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-02-2016, 10:22 AM   #8
Grumpy old man
I have a few sets still bolted to the 292 engines if someone needs some pictures ?
Old 03-02-2016, 10:32 AM   #9
Classic v6 GMC's
I think Mel is getting some pictures but if I need some I will you know.
Thanks, Andy
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-02-2016, 11:44 AM   #10
In The Ten Ring
I will take them if they are for a 292.
Old 03-02-2016, 05:11 PM   #11
Grumpy old man
Google the part # 3916784 and it comes back to Chevy 67-72 V-8 motor mounts 283 / 327 / 350 / 383 / 400
Old 03-02-2016, 06:03 PM   #12
Classic Bowties
Here are what the C/10-20-30 292 I-6 mounts look like, since questions seem to pop up fairly regular on this subject I also dipped into the old parts book for a look and found that the one above pictured C/10-20-30 SB V-8 #783 tower does have a 292 application listed but it is for 68-72 D-D/20-30 series used as left hand engine mounting to frame, maybe that is where the confusion started.
Also since the parts book was opened up, I crossed over the I-6 tower p/n's and confirmed that the LH #663 tower is the same part on all 63-72 C/10-30 w/292 I-6 and 66-72 C/10-30 w/250 I-6. The RH I-6 towers are completely different, the 63-72 C/10-30 w/292 used a #668 RH tower while the 66-72 C/10-30 w/250 used a #664 RH tower. Also per the parts book, the #291 bracket/cup on the motor itself is the same used on both LH/RH 292 I-6 and the LH 250 I-6, the RH 250 I-6 bracket/cup was #292. Mel.
Old 03-02-2016, 06:07 PM   #13
Classic v6 GMC's
Well then they must be for a v8. Makes me wonder how someone thought they were for a 292. I will change the thread.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-02-2016, 06:12 PM   #14
Classic Bowties
Yes, I thought the same thng as mentioned up in post #5, I also listed a possible reason for the 292 vs ? confusion in above post #12. Mel
Old 03-02-2016, 06:17 PM   #15
Classic v6 GMC's
Thanks for the information and your time.
Andy
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-02-2016, 06:26 PM   #16
Classic v6 GMC's
Re: NOS 1967-72 V-8 Engine Mounts
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-07-2016, 11:20 AM   #17
Classic v6 GMC's
ttt
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-11-2016, 06:34 PM   #18
Classic v6 GMC's
bump
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-16-2016, 11:15 AM   #19
Classic v6 GMC's
ttt
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-22-2016, 06:19 PM   #20
Classic v6 GMC's
top
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-26-2016, 11:59 PM   #21
Classic v6 GMC's
ttt
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-31-2016, 09:25 AM   #22
Classic v6 GMC's
top
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 04-05-2016, 12:58 PM   #23
Classic v6 GMC's
ttt
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 04-09-2016, 10:16 PM   #24
Classic v6 GMC's
top
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 04-16-2016, 10:57 AM   #25
Classic v6 GMC's
ttt
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
