Old 03-01-2016, 10:04 PM   #1
sampsmit000
sampsmit000's Avatar
Steering column
I need to get a steering column for my 1964 k10. It has a 350 turbo transmission in it. What years of used ones could I use, and is their any good repo steering columns for this application. Any info would be great.
1964 Chevy Factory K10 Short Bed
Mitchell Sampson
sampsmit000 is offline   Reply With Quote
Old 03-01-2016, 11:51 PM   #2
Heater63
Heater63's Avatar
Re: Steering column
There are a lot of threads here about inexpensive swaps from other GM donor vehicles. Stay away from eBay/chinese repops. If you want a new repop, Flaming River and ididit are worth the $$$ (500-800 approx)
I just installed a new Flaming River today, a great unit that will outlive me. There website can be a bit confusing, so use their "live chat" or email them.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 03-03-2016, 08:57 AM   #3
chevykevy
chevykevy's Avatar
Re: Steering column
I used a 68-70 column which has the steel framed gear indicator and used all the linkage from the 67-72 trucks. I Like the look of the indicator, still 60's look.
chevykevy is offline   Reply With Quote
Old 03-03-2016, 09:01 AM   #4
chevykevy
chevykevy's Avatar
Re: Steering column
Pic
Old 03-03-2016, 09:36 AM   #5
sampsmit000
Re: Steering column
Did you have to make any modifications?
Mitchell Sampson
Old 03-03-2016, 10:56 AM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Steering column
You can use a stock 2 speed column if one comes around. You can get a 3 speed indicator for it. I have a 2 speed column that I will be using on a 700R4 and will probably not be able to shift into low gear manually. The 3 speed shouldn't be a problem though.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-03-2016, 11:08 AM   #7
sampsmit000
Re: Steering column
So if I have a powerglide column is that what you are talking about when you say two speed?
Mitchell Sampson
Old 03-03-2016, 11:53 AM   #8
Chevy Fleetside
Re: Steering column
yes
Old 03-03-2016, 08:47 PM   #9
chevykevy
chevykevy's Avatar
Re: Steering column
the only modification I had to make was to the wiring and add a hazard circuit. Separating and connecting the wires. I think all the colors are the same just separate the plugs on truck side. I used a exhaust clamp to secure the column under the dash because the stock mount is different.
