03-02-2016, 02:38 AM | #1 |
Gasket remover
I'm trying to remove the old paper gaskets under the access covers on the side of the 4spd xmission on my C20. I had some old NAPA spray gasket remover that worked pretty well, but they don't sell it anymore. I tried Permatex remover. It is better than nothing, but not much. Any recommendations?
03-02-2016, 03:59 AM | #2 |
Re: Gasket remover
razor blade? Scrape scrape scrape
'68 C10 SWB '85 K30 Blazer |
03-02-2016, 10:22 AM | #3 |
Re: Gasket remover
I've used those "Scotchbrite Roloc Disks" with an angle die grinder, just use the medium or fine grit stuff, I think its gray or blue in color.you don't want to dwell in the same area too long, it will remove metal if you do.
Just a recommendation. Ben |
03-02-2016, 11:28 AM | #4 |
Re: Gasket remover
Wire wheel on a 4" grinder does it for me!
Mike. |
03-02-2016, 02:31 PM | #5 |
Re: Gasket remover
I've had good results using a heat gun to soften the gasket and its adhesive and permit easier scraping but not in a confined space where plastic or rubber parts are nearby or especially where there are automotive oils or fuel of course..
03-02-2016, 02:52 PM | #6 |
Re: Gasket remover
...until a piece of wire from the wheel ends up it the case/engine/whatever...scary. I am in the razor blade crowd. But, on most of the car shows, you see them using die/angle grinders with what is probably scotch-brite pads. For me, that is uncontrolled debris flying everywhere.
03-02-2016, 03:19 PM | #7 |
Re: Gasket remover
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
03-02-2016, 03:22 PM | #8 |
Re: Gasket remover
I have a "gasket scraper" tool in my tool box (see above), but generally it only gets used to scrap grease from parts I am cleaning up. Not sharp enough for most gasket removal tasks.
03-02-2016, 08:15 PM | #9 |
Re: Gasket remover
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
03-02-2016, 08:21 PM | #10 |
Re: Gasket remover
Razer blades always worked for me
03-02-2016, 09:48 PM | #11 |
Re: Gasket remover
Thanks for all the thoughtful responses. I ended up using a single edge razor blade. There was enough room to get to it.
03-03-2016, 01:28 AM | #12 |
Re: Gasket remover
Elbow grease never let me down
