03-02-2016, 12:47 PM | #1 |
How many amp are the glass fuses in cab?
Wiring my 70 c10 back up, and I can't quite read the fuse panel to see how many amps the fuses I need are. So far I need the PNL Lights, Cluster Feed, and the one top left of the whole panel
03-02-2016, 01:04 PM | #2 |
Re: How many amp are the glass fuses in cab?
Maybe this will help
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
03-02-2016, 01:06 PM | #3 |
More info
Fuse Requirements Table 11-1 Fuse Requirements 28 Cigarette Lighter 20 Headlight Switch 30 Emergency Flashers . 15 Turn Signals . 15 Gauges 10 AC/Heat Relay 5 Radio (Constant) 10 Horn .. 20 Door Lock .. 20 Wipers . 15 Brake Switch 20 Dome/Trunk . 10 Electric Fan Relay 5 Power Antenna 10 Power Windows .. 20 Electric Fuel Pump . 15 Coil . 30 Radio Ignition (Switched) .. 10 Backup/Cruise Control . 10
03-02-2016, 01:09 PM | #4 |
Found this - it is a little different than above but looks like the one in my 70
03-02-2016, 07:22 PM | #5 |
From the 70 Factory service manual which you should have and use. Its even in the driver's handbook.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
