Old 03-02-2016, 05:13 PM   #1
Task Force Era
Task Force Era's Avatar
8-lug Chevy patterns??
Alright I need to move around the behemoth 56 panel I got. It's kinda buried in the yard on 4 flats. It's 8 lug so my question is, are all Chevy 8 lug patterns the same? I did a search but it didn't go back to the 50's years.
I found some wheels on craigslist for a deal and they came off of a '97 C2500. Will they fit on my panel??
Task Force Era is offline   Reply With Quote
Old 03-02-2016, 05:19 PM   #2
ptc
ptc's Avatar
Re: 8-lug Chevy patterns??
Should be the same just have the guy measure them for you. Measure a straight line across axle center between 2 studs.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 03-02-2016, 05:37 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Chevy or ford will work except the for ford 7 lug. . don't ask why. they just have it.
dwcsr is offline   Reply With Quote
Old 03-02-2016, 06:09 PM   #4
Task Force Era
Fords man,
I did find a thread on another site that said Chevy changed the 8 lug pattern in 2011 trucks and up to a metric pattern.
Old 03-02-2016, 06:35 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Originally Posted by Task Force Era View Post
Fords man,
yes they went to 6.69" from 6.5 if you stay under 2000 you should be ok
Old 03-02-2016, 08:40 PM   #6
1project2many
Wheels with a large offset may have a problem with the inside of the wheel hitting the steering knuckle or the tie rod.
Ford also has ten lug wheels.
1project2many is offline   Reply With Quote
Old 03-03-2016, 03:20 PM   #7
Apachemike
Apachemike's Avatar
Yes the lugs will fit. On my 58 the front wheels WILL NOT go on. I needed 1.5" spacers for the to clear. Rears were no problem. Don't remember the year but older Fors 8 lugs fit but the newer 8 lugs went to a smaller diameter hub. The ones I got were 16" wheels FYI
Apachemike is offline   Reply With Quote
