Old 03-02-2016, 06:06 PM   #1
mancad
Ever seen a bolt like this?
This came out of a 1968 C20 4spd transmission side cover. The threads would not come clean with a wire brush so I got a small screw driver and picked it clean. The residue in this area was brown/black, fairly tough, and fibrous. When cleaned, it showed this notch machined into the threads. All 12 bolts were the same. I'm guessing they pressed in a piece of plastic or fiber to keep the bolt from loosening; maybe it helped seal the hole as well. I've not run across this before. It must have been a fairly expensive solution.
mancad is offline   Reply With Quote
Old 03-02-2016, 06:23 PM   #2
rcazwillis
Re: Ever seen a bolt like this?
Appears to be some sort of lock bolt like a nylon lock nut. Never seen one before.
rcazwillis is offline   Reply With Quote
Old 03-02-2016, 06:49 PM   #3
kwmech
I haven't seen any of those for years, so yes I've seen them before
Old 03-02-2016, 06:56 PM   #4
indymachinist
They still make bolts like that although they aren't that common.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
