Swapping in hydraulic clutch pedals....what do I use for nuetral safety?
first of all my truck is an '88 V30 and was a factory auto truck. I am swapping in a set of period correct pedals and need some advice on setting up the neutral safety switch.
My original auto column has a switch at bottom of the column. It has 2, 2 wire plugs going to it. I'm guessing one is a neutral safety switch and a 2nd plug for the reverse lights. My first question is........is this really a neutral safety switch because the later model columns had an ignition switch interlock I thought not allowing the ignition switch rotate forward to start in gear. If that is true could this plug be intended for something else? If it is in fact a neutral safety switch I had planned on using the wires and routing them to my clutch pedal switch to act as a neutral safety switch. Does anyone see a problem with this?
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 |
Moderator
![]() Join Date: Oct 2008
Re: Swapping in hydraulic clutch pedals....what do I use for nuetral safety?
One should be Neutral safety and one backup lamps.
That's how I'd do it.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Well I will get that wired up as soon as I find the 4 pin pigtail that plugs into the clutch/nuetral safety switch, lol
Moderator
Honestly I ran my 1985 without the clutch interlock and never missed it.
Since its a TBI truck and my daughter is 5 I would hate to have her hit the key and take off. I personally could live without it but I feel more comfortable knowing its there so an accident doesn't happen
Moderator
Two pins on the clutch switch are needed if you have cruise control.
#7 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=699703
I am by no means a guru on the electrical systems on these trucks but I think you will find the neutral safety switch on yours only turns on the reverse lights and tells the computer that the transmission is in neutral. The neutral safety is a mechanical lock out built into the steering column. My non-computer '86 doesn't even have a wire on that terminal. My hydraulic clutch had the wires cut and wire nutted together, probably because the safety switch failed. I found a wire harness in a wrecking yard and swapped the cut wires for non cut ones and bought a new safety switch.
#9 | |
On a manual transmission it is referred to as a clutch pedal position switch. There is a connector with purple and yellow wires, if I remember correctly, that connects to the column on an automatic shift. To use it with a standard transmission, there is a pig-tail that runs from the wiring for the automatic and connects to the clutch pedal position switch mounted on the pedal assembly.
'87 Chevy V20 Suburban 6in Lift, 37in Toyos/Nittos on 17x9 KMC Diesels 2009 Chevy Silverado 2500HD 6in Lift, 35in Toyos on 20x9 KMC Monsters |
