What screws in passenger side of block?
I was filling up with water to start new build and water came out this hole. Can somebody tell me what goes here? And what size, it's really close to the header flange so does it thread in past flush with the block?
Re: What screws in passenger side of block?
Hole is for temp sender. Looks like 3/8 pipe thread
You can plug it if you aren't using it. Well that's kind of silly for me to say, I guess you either plug it or you ride around on the core support pouring more water into the radiator as you drive down the road.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I believe that's 1/2" pipe threads on those holes...
Ben ![]() |
![]() Join Date: Oct 2010
Passenger side hole is a plug only. Temp sensor should be on drivers side. Mine has female hex head plugs.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
Get those plug wires off the header before you ruin the MSD wires and your day. Jim
Temp sensor installs on driver side, NPT plug on passenger side
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
