Old 03-03-2016, 02:34 AM   #1
dixiepc
K5 Body Swap
How much trouble is it to put a 1984 K5 body on a 1979 K5 frame?
dixiepc is offline   Reply With Quote
Old 03-03-2016, 07:38 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: K5 Body Swap
I believe the 73-91 frames are the same.
One thing to consider is DMV issues with fame VIN number different from body/title VIN number...
Rich
1972 K5 Blazer CST Click HERE
Old 03-03-2016, 09:32 AM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Re: K5 Body Swap
I think the front frame horns are all that will be different, IIRC you'll have to trim them to use the 84 front bumper and brackets.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-03-2016, 11:12 PM   #4
nvrenuf
Re: K5 Body Swap
The frames changed in 81 and again in 83. I believe the rear seat floorboards are a different height which changed the shape of the frame in the middle.
John
'91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's
nvrenuf is offline   Reply With Quote
Old 03-04-2016, 08:17 AM   #5
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Re: K5 Body Swap
The rear passenger foot well changed between 77 and 78 which necessitated a frame change. 78 through 91 frames are essentially the same, and 73 through 77 are the same. IIRC, but pretty sure that's accurate.
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
