Old 09-23-2003, 09:00 PM   #1
Rob'68
a/c, non a/c cab difference
At some point before I bought my truck, a/c was added. It was originally a non-a/c. Holes were cut in the dash in the correct places for the vents. It's attached to the firewall with self-tapping screws. You can see where the original holes were. My question is this: What is the difference between a/c and non a/c firewall openings? I need to make sure everything works ok before the cold weather gets here. Thanks.
Rob'68 is offline   Reply With Quote
Old 09-23-2003, 09:52 PM   #2
Hutch
Hutch's Avatar
Rob'68
Here is a pic of a 68 factory a/c cab firewall
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 09-23-2003, 09:53 PM   #3
Hutch
Hutch's Avatar
and here is a 68 non a/c cab firewall.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Old 09-23-2003, 10:02 PM   #4
Hutch
Hutch's Avatar
Rob'68
There are a couple of other differences if you look at the first cab there is a hole in the firewall next to the chalk mark number 2on the left which allows a flap to be mounted inside the cowl area to open and close via a vacuum assisted module.
There is also another device that is vacuum operated which is attached to the passenger side cowl vent on the kick panel.
These have to do with the fresh air circulation.
Other will supply more detail, as this is a common upgrade
All in all if I were doing it I would look into aftermarket as they are much more efficient and the final cost is about the same
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Old 09-24-2003, 07:30 AM   #5
ddsmith
Glowing since 1978
ddsmith's Avatar
This is interesting. I put in an Old Air unit in my truck and if I had to do it again I would replace everything except the evap/txv and maintain the normal control functionality. This is just my opinion. If you look at 69SixPackBee post you'll understand why. If going to R-134a, the POA can be adjusted to provide the proper setpoint. Anyone interested in further details can PM me and I'll explain further.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
