Old 09-23-2003, 09:15 PM   #1
WB72
Before and After
WB72's Avatar
3 point seat belts
I know this has been asked numerous times before, But I never paid much attention to them because I thought I would never put them in me truck. But I am seeing more reasons every time I think about it.
Which donor vehicle will work in our trucks?
Are there any, and mean ANY, probems when I install the upper bolt to the cab? It will have new paint, and I would hate to screw that up.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 09-23-2003, 10:05 PM   #2
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
I used 90 s10 blazer belts, but I also have buckets. I'm not sure how the female part would work on a bench seat.
the only issue I had with the upper bolt was the nut in the cab was rusted and i had to tap it out. other than that, no problem.
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
Old 09-23-2003, 10:37 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
I bought a pair out of a '86 or so S-10 pickup, standard cab. I think the ex. cab belts are a little different. Cost me $30 and is the best upgrade for the dollar i have made to my truck.
$30 is cheap considering it could save your life, or being hurt pretty bad
Anyway, make sure to get the outside parts with the retractor, as well as the female ends that come through the seat.
On my bench seat truck, i simply un-bolted the passenger side belts, and installed the new belts. Everything bolted in, and the female ends were the perfect lenght to come through my seat.
The driver's side went in the same way, except i had to drill a hole about 4" forward of the stock hole for the floor mounting of the retractor. I used grade 8 hardware, except for the top mounting point. I couldn't find any grade 8 fine thread fasteners anywhere, so i used grade 5.
Overall, you will feel much safer after the upgrade
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-23-2003, 11:41 PM   #4
krue
Designated A-hole!
krue's Avatar
If you have a stock bench seat you will also have to extend the floor mounts under the seat by about 4inches. I just took some 2 in flat bar and made an extension.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 09-24-2003, 01:09 AM   #5
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
here are the S10 belts with a stock bench seat
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 09-24-2003, 01:11 AM   #6
Bill72BB
Bill72BB's Avatar
here they are with a 98 bench seat installed.
BILL
Member DUF Club
Old 09-24-2003, 04:23 PM   #7
Brad
Out of the carpool lane.
Brad's Avatar
Look for my post in FAQ. I posted on this about a 9months ago.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-24-2003, 10:56 PM   #8
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Bill, what seat is that out of??? Did any of the mounting holes line up? Thanks...
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 09-24-2003, 11:11 PM   #9
useRc10
useRc10's Avatar
mine came out of an 80 something suburban and bolted right in with the exception of having to extend the bracket to clear the edge of the seat...also, be sure that the donor truck was not wrecked...this weakens the web
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
