Old 03-04-2016, 06:01 PM   #1
wildfifty2
454 in a 52 1/2 ton??
Anybody ever put a Chevy Big block in a 52 Chevy truck with stock frame and suspension? I have a spare crate motor and have been considering putting it in my 52 with an automatic trans. but I do not want to mess with cutting the firewall or floorboard in the truck. Can this be done with an aftermarket cross member with side engine mounts and a new transmission cross member? I know all about tight fitting applications as I put a big block in my 56 sedan.. If I did not already have the 454... I would probably just order up a small block and make my life much easier.. Anybody done this swap?
wildfifty2 is offline   Reply With Quote
Old 03-04-2016, 06:16 PM   #2
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: 454 in a 52 1/2 ton??
I'm seeing a few guys say if you use a small cap HEI a short pump and electric fans it should work other things to consider are headers and the steering shaft a lot of guys need to move it to the side out of the way to slide it together keep us updated!
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 03-04-2016, 06:45 PM   #3
wildfifty2
Thanks for the info... Sounds like my 56 swap.. I used an MSD electronic distributor and a short water pump along with electric fans and Sanderson block hugger headers. I am curious if the stock pan will fit. On the 56 I had to switch to a Milodon pan for more clearance.. Also I used a Muncie 4 speed so I am not sure if a turbo 400 would need more clearance..
Old 03-05-2016, 12:09 PM   #4
_Ogre
_Ogre's Avatar
your 56 was designed and sold with a sbc, the 52 was not
you will need to relocate the steering box
shop air compressor timer
Old 03-05-2016, 08:57 PM   #5
wildfifty2
Thanks... Any tips? It is a major project?
Old 03-05-2016, 09:03 PM   #6
mphudak
this speaks to a SBC but would be close for a BBC
http://53truck.ez15loan.com/howto/install-v8.htm
55.1 GMC Suburban Hydramatic
mphudak is offline   Reply With Quote
Old 03-06-2016, 01:09 PM   #7
_Ogre
_Ogre's Avatar
depends on what your level of fabrication expertise is
Old 03-07-2016, 07:39 AM   #8
YahamaR1
YahamaR1's Avatar
I did it, iTS a tight fit
Have a other firewall
A other transtunnel
Frontend from scotts hotrods
But it looks good, see my build thread
YahamaR1 is offline   Reply With Quote
Old 03-07-2016, 11:04 AM   #9
Coach529
Coach529's Avatar
My biggest concern would be the interference with the column and steering box. SBC is pretty tight in that regards.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 03-07-2016, 11:06 AM   #10
Coach529
Coach529's Avatar
Not sure who's truck this is, found it in my picture stash.
1949 Chevy 3600
Old 03-07-2016, 02:24 PM   #11
wildfifty2
Thanks for the info and pictures.. It helps a bunch to see it in pictures..
